Question about Foxconn Cinema Deluxe AMD 785G Socket AM3 mATX Motherboard w/HDMI DVI Audio Gblan & RAID (020F1H69BG50Q)
I have a HP HPE-210y purchased for drawing graphics. I can't get into BIOS. I have tried every combination of "F" keys, delete, escape, and so on. I even replaced the CMOS battery last night. Please help, Motherboard is Foxconn H-RS880-uATX (Aloe). The form factor is uATX, and the chipset is AMD 785G. Thank you!
  • rbhinely Mar 14, 2011
    I apologize for taking so long. I just tried your solution - put the jumper on pins 2 and 3, waited a minute, and switched the jumper back to pins 1 and 2. Tapping F10 at startup, it again bypassed BIOS and went to logon. Do you have something else I can try? Thank you.
  • rbhinely Mar 15, 2011
    Yes, your solution worked. One thing I added, don't know if it made any difference or not, was remove the CMOS battery prior to moving the jumper. Once I moved the jumper to the second and third pins, I reinstalled the battery. It may not have helped, but it obviously didn't hurt. Thank you very much for your solution.
  • 2,632 Answers
Welcome to Fixya. If you want to go to the BIOS screen reboot the computer and on the POST Screen Tap Delete Button on your keyboard.
You can also the the messge on the Post screen to Press the DELETE button to go to Setup.
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 14, 2011
  • Rofel Lantican
    Rofel Lantican Mar 14, 2011
    Correction on the answer above. Hold down the F10 key during the startup process and enter BIOS setup. Don't just tap the F10 key hold it when restarting on the POST SCREEN.
    You can refer to the manual below.
    H-RS880-uATX (Aloe) Manual
  • Rofel Lantican
    The steps on how to go to bios is on the Clearing the Password Settings on the manual
    President:
  • 1,961 Answers
Using the BIOS setup utility The Basic Input Output System (BIOS) is responsible for enabling the hardware system on your computer when the computer is turned on. The BIOS Setup Utility makes it possible to change and store system configuration settings such as: which onboard components are enabled, the boot sequence for the system, and adjusting power management support. To open the BIOS Setup utility, turn on the computer and immediately press the F10 key repeatedly, about once every second, until the BIOS setup utility screen opens. Choose menu screens by pressing the left or right arrow keys. Use the up or down arrow keys to move up or down through the list of items on a menu screen. Press the Enter key to select an item for modification. For certain items, pressing the Enter key opens a submenu. After you have selected a menu item, use the arrow keys to modify the settings. Press the Esc key to exit from a submenu. Help is shown on the right side of the screen.
CAUTION: Information stored by the Setup program is essential and changing certain settings can render your system unusable (until the BIOS is reset). BIOS settings should not be changed unless you are certain the change does not negatively impact the system.
for more information follow this link if the procedure did not work clear firs the CMOS setting then reboot the computer press F10 to enter the bios set up
how to clear the BIOS setting
I have a HP HPE-210y - hpweb_1-2_plus.gif Clearing the CMOS settings
CAUTION: Do not change any jumper setting while the computer is on. Damage to the motherboard can result. This motherboard has a jumper to clear the Real Time Clock (RTC) RAM in CMOS. In the default (normal) position the jumper is on pins 1-2. c01925491.jpg
  1. Temporarily set the jumper to pins 2I have a HP HPE-210y - c01925492.jpg="http://i.fixya.net/uploads/images/c01925492.jpg" alt="c01925492.jpg" class="h_mi" />
  2. Wait 5-10 seconds and then return the jumper to pins 1-2.
  3. On the next startup, enter BIOS setup to reset any custom BIOS settings.
  • Danilo Baraquiel
    Danilo Baraquiel Mar 15, 2011
    ok.please dont forget to rate,,
Where on the motherboard hp aos-d 620887-001 to plug in the power reset & hdd led
try looking here ..you need to look for pw which the power switch that need attaching to
Jun 13, 2017 | HP Computers & Internet
Hp presario CQ62 esc key not working
its usually F2 or Delete button to access the bios, have try that
Feb 23, 2013 | HEWLETT-PACKARD HP Compaq Presario...
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 05, 2013 | Dell Latitude D800 Notebook
DC7600 Wont boot from win 2003 CD
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
Hope this helps
Dec 09, 2012 | HP DC7100 PC Desktop
What keys change bios values on asus u46e
this will set the boot order
hope this helps
if this fails you might try some of these
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
Reset bios motherboard
hope this helps
Jul 09, 2012 | HP PAVILION DV4000 SERIES 100GB HARD DRIVE...
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
Need to restore Older Celeron Desktop. What are the command keys to push when starting the CPU?
コナミコマンド
No wait that's probably not it.
Your probably trying to get into the BIOS screen.
Try each of these in order:
Delete
F1
F2
F3
F5
F10
Escape
Insert
Control + Escape
Alt + Escape
Control + Alt + Escape
Control + Alt + Enter
If none of those work try web searching "BIOS key for xxx (your Desktop manufacture and model)".
Jul 19, 2010 | Intel ZT Celeron D 3.46G Desktop Computer...
How to do the CMOS setup in HP Compaq DC5100 SFF (PM215AV)
Common  keys are delete, f1, f2, f3 , f5 , f10 , escape and insert If these dont work, then check on Hp's page for your computer; you should be able to download a manual.
May 23, 2009 | HP Compaq dc5100 Small Form Factor PC...
Video card probs
BIOS settings are accessed as soon as you turn on your computer, usually by pressing one of these keys: delete, F2, space bar, or escape.
If you post exactly what computer make and model you have, or what motherboard if it is custom built I can tell you for sure.
Apr 19, 2009 | HP GeForce FX 5200, (128 MB) AGP Graphic...
Foxconn Cinema Deluxe AMD 785G Socket AM3 mATX Motherboard w/HDMI DVI Audio Gblan & RAID (020F1H69BG50Q) Logo
247 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
