Question about Whirlpool LSQ9549P Top Load Washer
Washer wont agitate - Whirlpool LSQ9549P Top Load Washer
  • 4,399 Answers
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya.
Posted on May 01, 2011
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
Jun 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Amana heavy duty washer wont agitate with clothes in the washer
please post your model number for futher assist...
Apr 07, 2009 | Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool LSQ9549P Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
