Question about RCA RP4803 Clock Radio
How do you set time on RCA RP5435B - RCA RP4803 Clock Radio
    Problem Solver:
  • 9 Answers
Use the manual in the following link. It's for a similar model, so perhaps they work the same.
http://portablemedia.manualsonline.com/manuals/mfg/rca/rp5430.html
Posted on Mar 14, 2011
2 Suggested Answers
mindreader
  • 578 Answers
SOURCE: I unplugged my model RP5435B clock and when I
FIRST!!! Replace the "standby" 9V battery. Then unplug and replug... you should now be able to set the time.
Posted on Feb 03, 2010
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
How do i change the time zone on my rca 7 voyager?
Touch the "settings" icon, go down to the "System" area, and touch the "Date and Time" icon : you can either set the time zone to automatic (rely on the network), or immediately manually change the settings time, and time zone.
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
RCA Model RP3765 manual
Hi Arlene, Your clock should actually set its own time if the two Double batteries are installed. If not click link and follow instructions RCA RP3765 User Manual Setting The Clock Setting Clock
Good luck
Nov 04, 2014 | Audio Players & Recorders
The power went out and my RCA tv needs to have the time set to continue watching. But the remote does not work, and I can't access the menu from the tv
Hello
If the remote control doesn't work, just buy one RCA RCR model universal remote control. Without remote control, you can't set the time to this set.
Mar 04, 2012 | RCA Televison & Video
I accidentaly turned the FPA lock on my TruFlat RCA tv and the original remote broke. i just bought a RCA universal remote from best buy. now how do i get rid of the lock?
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Aug 24, 2011 | RCA TruFlat 27F520T 27" TV
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 | Vacuums
I unplugged my model RP5435B clock and when I plugged it back in to the outlet the time will not set. How do I set the time again?
Feb 03, 2010 | Audio Players & Recorders
RCA Universal Remote #RCR451
Many times someone will accidentally push the wrong button, or some remotes have tio be re-set when batteries have been removed and the code needs to be re-set. Go to remotefinder.rca.com/default.aspx?site=rca for your code. Sometimes more than one code is given for an individual remote. All must be tried until the proper one is found.
Oct 24, 2008 | RCA Universal Remote Control
RCA RP5435B SN.1A006J255A0594-Clock running slow
Most of the Radio clocks by RCA are meant to be used with 60Hz AC line. This problem will not go away unles you can get a custom built 60 Hz AC power supply, may prove to be too expensive for the clock.
Sep 20, 2008 | RCA RP5430 Clock Radio
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Sep 20, 2007 | RCA Radio Alarm Clock
RCA RP4803 Clock Radio Logo
439 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
