Question about Hitachi 51S500 51" Rear Projection HDTV-Ready Television
The picture is fine but the power will cycle on and off every couple of seconds the after a while it will come back on and be ok....or it will stay off for a period of time then come back on out of the blue
  • yoneystoo Mar 15, 2011
    the LED goes off sound goes off tv shuts off....for a couple seconds then powers on again picture, sound LED all come on for a second then ofdf again....
  • yoneystoo Mar 17, 2011
    not very good...
  • 4,889 Answers
Do you mean only the screen goes off and sound remains or does the tv go off altogether? Also what is the status of the LED at the front when it goes off?
Posted on Mar 14, 2011
  • eagle338
    eagle338 Mar 15, 2011
    The source of the fault is undobtedly the power supply board. Most likely cause is faulty electrolytic capacitors. How good are your electronics/soldering skills?
  • eagle338
    eagle338 Mar 17, 2011
    Ok atleast do you know the basics like using a multimeter, knowing about which components hold residual voltages etc.,? If not then I am afraid that you should leave this to a qualified tech. If that is the case please get me your zipcode so that I can get you a list of techs in your area
Proform perspective 1.0 lx console cycling off and on
There may be a problem with the wire lume that connects the LCB to the console.
Nov 10, 2013 | Proform Exercise & Fitness
Sanyo LCD TV has green light , no picture or sound.
You have the classic symptoms of a power supply failure. Visual inspection of capacitors is not a reliable method of solving the problem
Mar 08, 2013 | Televison & Video
All three lights blinking picture only stays
I was having this same problem - power cycling - exactly as described. The lamp turns on and the picture looks good for the 5-10 seconds it is on (this makes me question all the comments I've seen online saying it is a bad lamp that needs replaced).
Problems started with green lines on analog channels and erratic behavior that included freezing and shutting off occasionally. Now, it is to the point where I get 5-10 seconds of picture, then it freezes and starts the power cycle 5-6 times, chiming every time it automatically turns on, before finally remaining off. I have removed the back, dusted off fans/components/etc, supplied additional fan for airflow, and made sure the blue switch in the back is down. Still having the same problem!
Ok. I went through the standard warranty process, which means they sent me a replacement bulb saying that was the issue. No luck...same power cycling. Finally they sent a tech out who took a look and said he needed to replace the digital board. So, 2 weeks later, the part came in and the repairman came back out to install it. Voila, I have a tv again. (This is the same fix the supervisor at the call center said it needed months ago...before they sent me the lamp)
So...I would recommend having the tv's digital board checked. Especially if your tv is still under warranty, as it cost me $0.00 to fix. Chances are, they are still going to start by having you replace the lamp. Good luck!
Jan 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Monitor goes blank after a couple of seconds.
The problem can be the backlight inverter board or bad capacitors in the power supply section, I have seen bad soldering of the wires to the lamps are bad also.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 05, 2009 | Sony SDM-HS74P 17" LCD Monitor
1996 Geo Metro - when the head lights are turned on the the engine idles up and down. As long as the lights are off, everything works fine. RPM's go up to about 2000 for a couple of seconds and then back...
Sounds like you may have a faulty switch, or bad ground in the system. This will cause the fluctuating idle when additional load is applied to electrical system.
Oct 17, 2009 | Geo Metro Cars & Trucks
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hitachi 51S500 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
