Question about Nokia N95 Cellular Phone
Nokia N95 the chanise
My phone is just going on and off when i enter my sim card. then when i go to bluetooth it says ´´bluetooth initializing moment just wait´´ that is for 9 months now.
Yar tu kise de mobile to apne mobile par wallpaper send kar agar send ho gya to chal pade ge............
Posted on Aug 01, 2008
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
5
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
I GOT AN MMS TO MY MOBLE MUNBER 09291570522 JUNE 2 2011
my bluetooth "initializing bluetooth now,wait a moment.!"
Jun 02, 2011 | Nokia N95 Cellular Phone
How to know my pin code of my nokia N95???what are the procedure???
Hello m_cjharold,
With regard to PIN Code, it is the code of your SIM card. (example: AT&T, Cingular, Vodafone, Globe, Smart etc.)
If ever you have no idea what it is or if you forgot it, you can contact your service provider for the PUK code wherein you can enter once you used all the chances to enter the PIN Code.
To make sure, if your N95 is unlocked, meaning you can use different SIM Card, try using another SIM card and it should work fine. However, if it asked for Phone Code, it means you need the Security Code of the Nokia N95 not the PIN Code.
I hope this was helpful.
Thank you,
Jack
Feb 17, 2011 | Nokia N95 Cellular Phone
I was playing around with my puk codes and sim codes and now everytime i turn the phone on it says pin code blocked enter puk code ? pleasee helpp i need it for work
your PUK-code and PIN-code were delivered together with your sim-card. when the sim-card asks for a PUK, it is blocked until the PUK-code is entered. if you cannot find the PUK-code anymore, it is advisable to go to your service provider (cell phone dealer) and ask for a new sim-card with the same number. hopefully you had your contacts saved to your phone and not to the sim-card, because it's very unlikely that any data on a blocked SIM can be retrieved.
Mar 08, 2010 | Nokia BH500 Bluetooth Headset For N95 8GB...
Sim card not valid
Friend i have same cell phone and i am also facing this problem but dont worry
go to network menu and select Automatic network that problem will be solved if not them show it in to nokia care
Jul 22, 2009 | Nokia N95 Cellular Phone
Warning!bad contact charger
Jul 13, 2009 | Nokia N95 Cellular Phone
Nokia N95 puk code
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call your phone service company, they can retrieve the puk code from a database
for free.
In your case you need to contact your SIM card phone provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone should not ask for the PUK anymore.
Your rating is highly appreciated on this matter.
thank you,
Jun 29, 2009 | Nokia N95 Cellular Phone
Unlock Nokia N95 8GB
plz give nokia n95 master cod
Apr 05, 2008 | Nokia N95 Cellular Phone
My phone have PIN code blocked
You should get your PUK number from your service provider... no one else have it
Dec 28, 2007 | Nokia N95 Cellular Phone
Nokia N95 Bluetooth
Almost there gizmo1. In fact one has to go through Connect, Bluetooth then you'll see two tabs. The selected tab has the basic bluetooth options (On/Off, Visibility, name etc) and the second tab shows the list of paired devices. Access this by pressing right.
Once in the list of paired devices Press OPTIONS (normally the left softkey) then "New paired devices". You'll then see what's around and you'll be able to initiate the pairing.
If you're simply looking to send an object, you can do this from the file manager or media library. In the media library select your picture or other object then once again through the left softkey (Options) you should see a "Send" option. Select that, the Nokia will then propose how you wish to send. Choose bluetooth. In the file manager it works in the same way.
Sep 20, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
