Question about Electrical Supplies
I have one light in a room w/ 3 light switches to operate it. We want to eliminate one of the switches (has two 14-2 wires going to and coming from). The other two switches have 14-3 wires coming from them. How can we wire them up to use the remaining switches?
    Champion:
  • 235 Answers
I can help you with this problem but will need to confirm some details. Please confirm that the switch you wish to eliminate has two twin cables running to the switch mech. I'm not sure what you mean by two 14-2 wires. I am guessing you simply mean two twin cables. I'm guessing that the two twin cables have the same coloured building wires coming out of them. If so, remove these wires from the switch and join the same colours together. The other two switches will simply now work on a two way basis.
Posted on Mar 14, 2011
How to fix when headlight are on highbeam comes on also?
Replace the turn signal switch. All exterior lights run threw it, except the high mount brake light.
Mar 29, 2015 | Cars & Trucks
How to wire in an on-off switch for ceiling light from power source going to living room.
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Sep 20, 2014 | Electric Electrical Supplies
I want to replace two regular switches with two utilitech 7 day digital in wall timers.
Go to lowes or home depot and get a book on simple wiring. they have the same ones at the library.
Nov 08, 2013 | Intermatic Inc. ST01C Digital In-Wall...
Have dual light switches - one for fan one for lights on fan. incoming to box is white (neutral) black(hot) then out to switches two sets of w/b. fan has one each of the white, black blue(lights). How do...
From your switch box to your fan run a 14/3 wire. Take the incoming 14/2 white wire,and connect to white of the 14/3 wire to fan lite combo ,and hook both white wires from fan and lite. Hook the fan black wire to the black wire from the 14/3 Hook the black wire from the fan to the red wire from the 14/3. Then go back to the switches, and add a black and red pigtail about 4"long to the black wire from the 14/2, now connect the red wire to one side of switch, and the other red wire from the 14/3 to the other side of switch. Do the same to the black wire on the other switch.
Sep 17, 2011 | Garden
I am wiring 12 Leviton dimmer switches to light up a series of 12 halogen under cabinet hockey puck lights. I am bring power to the first switch through a 14-2 wire and using a pigtail to conduct power to...
You cannot wire dimmers in series and expect circuit to operate.
Problem is not 100% clear. Add a comment and include more information.
1) You have 12 dimmers.
Each dimmer has 2 black wires and a green ground wire.
The 2 black wires tell electrician that the dimmer wires are reversible.
One black dimmer wire connects to Hot from breaker, and the other black wire connects to wire going to Load (halogen lights).
If power passes through each dimmer going to next dimmer, the circuit will not work.
2) Unknown what you are replacing. Are you replacing 12 switches with 12 dimmers? Or maybe replacing 1 switch with 12 dimmers.
Number and type of devices being replaced is not known. And wires to each of these dimmers is not known.
3) You have a single 14-2 wire going to all 14 dimmers? Or does each dimmer have a different 14-2 wire?
4) You want to wire dimmers in series? So you want power to flow through one dimmer and control next dimmer?
You cannot wire dimmers in this manner and expect circuit to operate.
You can wire ordinary switches in series, but not dimmers.
5) Typically dimmers and switches are wired in parallel.
The Hot wire connects to one wire on each dimmer.
Since your dimmer has 2 black wires, the hot connects to either black wire on dimmer.
Then a jumper wire is added to connection, and the jumper wire carries power to next dimmer, and so on.
In this manner, each dimmer receives 120V potential. And then wire going to load connects to other black wire on each dimmer.
Sep 10, 2011 | Leviton Electrical Supplies
Install 2 way switch wire diagram
I think you mean that you need to wire a set of three way switches. That is when you have a switch at two locations to run the same load (lights for example). Without being able to draw a picture, I will try to explain this the best I can. You have probably 120 volts coming in on a 14-2 romex for a 15 amp circuit or a 12-3 romex for a 20 amp circuit consisting of a black, white, and a bare wire. You run that set of wires to one of the two switches. Then from that switch you need to run a type of 3-wire cable from that switch to the other. For example:14-3 romex for a 15amp. circuit or 12-3 romex for a 20 amp circuit. Do not reduce wire size if you start with 12 gauge wire coming in from the breaker. Then you again run a piece of 12-2 or 14-2 (depending again on the amp circuit you are running) from the second switch to the load or lights that the switches are serving. Now for terminating the wires. In both switch boxes you just connect the white wires together with a wire nut. The bare wires you also connect together with a wire nut, but also twist a short piece of bare wire in the wire nut. That tail will serve as your jumper to the green screw on the switch. Then all you should have left in each box is two black wires and a red wire. These three wires all go to the switch. On the switch you should have three screws on the sides. One is darker than the other two. That darker screw gets the black from the 14-2 or 12-2. Then all thats left is the black and the red that come from the 14-3 or 12-3. Those two go to the remaining two screws on the switch. It does not matter which one either goes on. That should do it now you just wire the light like you would any other.
Hope this helps. Any other questions feel free to email me.
P.S. Don't forget to turn off the power!!
Nov 23, 2010 | Hammering
I want to wire a 3 way switch with multiple lights between the switches. The easiest route and least wire used is power in at switch then to lights then down to second switch. would i use a 14/3 from...
You have to run the 3rd wire all the way to the switch, whether it hits any lights or not, I have seen electricians pull a single wire in to the box with the 14/2 and that would be the jumper. This will work on any lights, and the lights only need the 2 wires, It is just the switch that needs the 3 wires. Good luck.
Feb 22, 2010 | Lutron Dimmers S103PNL 1000W 3-Way, Preset...
I took a three gang face plate of now this switch is number 1 witch operates the hall number two switch operates the sitting room. number three operates the third light in the same room. but number three...
You need to determine where the power is coming into the box. That power line needs to be jumpered to each switch. The black of the lights will go to the other side of each switch. All neutral wires are tied together.
Bob Janelli
Oct 01, 2009 | Cooper Wiring Devices 3-gang Cooper Wall...
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Wiring a 3 way switch on 1 plate to 3 lights and 2 other switches
I have a light switch at the bottom of the stairs which works 2ways can be switched on and off up and down stairs and also an out side light on the same switch which I have messed up and would like a picture of the way it should be connected.
Sep 21, 2008 | Electrical Supplies
Electrical Supplies Logo
67 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
