Question about Admiral Dishwashers
Water will not drain after going thru a cycle.
  • Admiral Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Mar 14, 2011
Water does not drain at end of cycle
Could be drain pump , float switch, or PCB. Does it initially go thru a drain cycle when you start a cycle? Is there water in the bottom of the tub?
Oct 02, 2013 | Bosch 24" Built-In Dishwasher - SHE43R55UC...
After completeion of wash and before spin the machine is displating 4E and stopping the process. Water is remaining in the cylinder
This is common on machines that have a faulty water pump. Check the drain hose first to make sure it is not blocked. The water pump drains the machine before it can go to the spin cycle. If you drain the tub by hand and then let it go thru the spin cycle it is likely that your pump is faulty.
Nov 12, 2010 | Samsung Washing Machines
MY WASHER WILL NOT GO THRU THE CORRECT CYCLES. THE WATER WILL RUN FOREVER AND NOT GO TO THE NEXT CYCLE.
check your drain hose make sure it is not to far down the drain pipe causing a gravity siphon action.put the unit in a drain cycle to remove the water then pull the hose up some and try again.
if this does not work then you need to replace your pressure switch that determines the amount of water the unit gets
Mar 19, 2010 | Frigidaire ATF6000ES Front Load Washer
On all cycles the "f-20" code comes up & will not go thru rinse cycle. I have to manualy do the rinse cycle.
you need to check your drain pump for anything that maybe blocking or restricting the water flow when it does go into the drain cycle
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Front loader whirlpool washing machine won't go thru cycles.
"o" is an unsual code. usually it will have an "f" then a number. it may be that you are having a draining issue. is the unit full or have some water left in it? if so take off the front panel and see if you can remove the sump cover. be ready for water to come out, then remove whatever is blocking the pump and sump area. it most liekly has lint or items in there causing no drain.
Dec 28, 2008 | Washing Machines
Dishwasher will not go thru wash cycles
doy you hear any sound from either in the wash cycle
Feb 11, 2008 | Dishwashers
Washer won't drain
model number is LHW0050P,
thank you again,
Susan
Jan 13, 2008 | Washing Machines
Dishwashers Logo
150 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Mike Carew
richie46
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
