Question about Fujitsu 24C1 Air Conditioner
Have a Halcyon ASU12CQ Indoor Wall Mounted AC mini-split. Lately both the Operation and Timer lights on the front panel flash simultaneously, then both go out and only the Air Cleaner light remains on. Unit seems to be operational, but I am concerned since this is different behavior than when first installed. Should I contact service?
  • jennajonteau Mar 14, 2011
    Same question: issue is not time sensitive since the unit IS operational.
    I am attempting to determine WHAT the flashing lights mean (error codes) perhaps only a reset is necessary?
    Here is complete cycle from cold startup:
    Solid red (for operation)and solid green lights (for air cleaner)
    then approx. 2-3 minutes later (unit is still functioning);
    4 times both the red and green lights blink
    red light goes out
    3 times green air cleaner light blinks
    then BOTH lights go dark
    later both the red operation light and the green timer (timer is NOT being used) light both blink simultaneously.
    This is VERY strange behavior
  • Fujitsu Master
  • 2,098 Answers
Hi Jenna,
Do you remember how many times the blink is, this is to know exactly where the fault came from?
Jdvillanueva
Posted on Mar 14, 2011
  • Jdvillanueva
    Jdvillanueva Mar 14, 2011
    This error code indicated that the unit initial self test sense the ff:
    -(red blinks) force auto switch become on for 10 consecutive seconds ( checked if this is kept pressed if not this is most likely defective.)
    -(green blinks) power supply frequency can not be recognized after 4 seconds of power on.
    The a affected board is the controller PCB of the unit (for both blinks).
    Isolating the trouble needs to attend by qualified technician, I would advice you to inform the dealer as soon as possible most especially if the unit is still under warranty.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya
    President:
  • 2,047 Answers
Abnormal behaviour such as these are often signs of looming problems to come. If the behaviour is not regular with the unit it is best to contact service now before the problem gets out of hand. Although most times the unit might just need cleaning but you cant be too sure. Contact service to come and have a look at your unit.
  • Rockme
    Rockme Mar 14, 2011
    The flashing lights are not error codes. error codes mostly come with some sort of malfunction in the actual operation of the unit but presently no malfunction so the unit might only need some service.
The green operation light keeps blinking. I've reset unit and it still blinks
Could u explain more about this error,how many led light,flashing ??? Brand???model???
May 08, 2015 | Fujitsu HALCYON ASU24CL1 Wall Mounted Mini...
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
In winter the outside unit sounds like a rubbing/ticking noise
Sounds like ice coming of the coil. That would explain the ticking. The rubbing could be ice buildup before the defrost cycle or it's building on the blades of the fan throwing it of balance a bit.
Feb 13, 2015 | Fujitsu Halcyon ASU12RMLQ Mini Split Wall...
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Fujitsu aou30clx compressor location detection error
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
Apr 18, 2013 | Fujitsu 30CLX HALCYON Wall Mounted Mini...
AC unit
You should post this question in the air conditioner section so the proper experts will see it.
Sep 05, 2012 | Fujitsu Halcyon ASU9RMLQ Mini Split Wall...
Fujitsu ASU9RLQ
check indoor unit sirkit board
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
463 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
