Question about Bosch Water Heaters
Hi, I have a Bosch tf 400 ng 1tr, about 7 years old, just today it started producing only 1/2 the heat. Any suggestions ( I have gas experience on cookers and stoves) so I should be able to fix if I'm nudged in the rite direction.
You ask for free nudge:
I have links for resourceful do-it-yourselfer since tankless is large and developing field that can take years of study.
For example tankless are prone to lime build-up and must be de-limed each year. Search utube for 'delime tankless' to help restore efficiency.
Best place to start is troubleshoot section in your product manual.
1) BOSCH website is easy to navigate:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
2) Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
3) Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
4) Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
5) All costs are energy. Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/pro-n-con.html
6) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 16, 2011
Water is way too hot. Five year old GWH2400E NG is giving error code EC: Ionization failure during operation. set point temperature = 106, inlet water temp = 88, outlet water temp = 171, water flow = 12,...
Before calling service technician who has service manual and can test which part has failed, open following links for troubleshooting resources including steps below and phone number for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
Clean inlet filter
Check all faucets for clear pathway
This unit does not work with preheated water (solar assisted)
Incoming water above 70 degrees, avoid restricted faucets
Check that both temperature sensors are making contact and firmly mounted on respective cold and hot pipes.
Descale heat exchanger
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G2-13_Descaling.pdf
Aug 16, 2011 | Bosch AquaStar 2400ES-NG
Gas outdoor mounted AQ250 won't stay lit. Unit is about 2 years old and has been working great.
Before calling service technician, open following link for Bosch troubleshooting resources.
Sample manual has troubleshoot section and yearly maintenance requirement.
http://waterheatertimer.org/pdf/Bosch-250SXO.pdf
Service bulletins for 250SXO
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
Tankless require yearly maintenance as outlined in manual.
No tankless manufacturer suggests do-it-yourself repairs on their product, in part for liability and danger to customers, but for long-term customer satisfaction.
Repairs and yearly maintenance will eliminate the $1-8 monthly energy savings expected from owning tankless.
Apr 19, 2011 | Bosch AquaStar 2400ES-NG
Replaced thermocouple on Bosch TF250. Now the pilot flame is so big that it heats and boils the water in the heat exchanger when hot water is not required. When we turn the tap on, we get dirty water,...
Before calling service technician, open follow links for troubleshooting resources.
Bosch site does not show TF250, but shows 250SX and 250SXO.
Gas Products Technical Support: 800-642-3111
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/tabid/370/Default.aspx
At no time when visiting tankless website have I read suggestion that people fix tankless as a do-it-yourself project. In fact each site says repeatedly to call service technician for installation and repairs.
When reading service bulletins, the repair protocols are generally long and very sequential, even if a thermocouple seems straightforward there are many interrelated parts and sensors that must communicate exactly with each other.
Example: following pdf outlines operation sequence for non-standing pilot model
http://waterheatertimer.org/pdf/Tankless-gas-operation-overview.pdf
The dirty water also suggest that tankless has not gotten regular maintenance that is required for continued operation. Tankless are not install-it-and-run-flawless-for-years type of machine.
Read manual for specific maintenance required for your model. For example yearly flushing the heat exchanger with vinegar to avoid lime build-up is suggest most models. Tankless are succeptible to lime build-up.
All costs are energy. Maintenance alone can easily eat up the promised $1-8 monthly savings from tankless vrs tank-type water heater. One service call can wipe away years of expected savings, plus replacement part can sometimes cost as much as whole new tank-type water heater, installed.
Apr 17, 2011 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
My old Aquastar tankless natural gas water heater used 1/2" gas line. My new Bosch 2700ES -NG says it requires no less than 3/4" inside diameter gas line. Do I have to replace all the gas supply lines...
None !!
3/4 pipe from gas meter or regulator. At low pressure there may not be enough gas flow through a smaller pipe for the boiler when on full bore.
The boiler input pipe will be 1/2" needing a reduction from 3/4 so there is some leeway.
I have about 8' of 1/2 pipe on mine [Bosch Worcester] from the reg. and it is ok.
You could use the existing 1/2 and try. No harm done if insufficient-just replace. If you have some other gas takeoff on the same line a 3/4 pipe up to that take off is most likely.
Jan 29, 2010 | Bosch 2700ES Natural Gas AquaStar ...
Had the unit for seven years, it started to leak water around the water valve. Bosch aqua Star 125x ng
You have to fix this leak around the water valve before
it causes damage to your equipment.
1. Close the water supply valve going to your tankless
water heater.
2. Unplug or close the natural gas valve.
3. Now, you can work fixing the leak.
4. Once completed, you can proceed to open the
natural gas valve as well as the water supply valve.
5. Then, have it tested to get it done.
5.
Nov 27, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch 16p gas, keeps going hot and cold
check the thermostat, you will probly need someone that has worked on the same kind of unit, they are not all the same {tankless} I would suggest a repairman,, there is a little bit much to explain how to do it over the internet,
Jun 22, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
On demand water heater won't stay lit
It's the gas valve. This pretty common. The thermocouple produces a small amount of current from the heat and this current holds the safety valve open inside the gas valve. Sometimes the safety valve gets sticky and your symptoms describe it exactly. People are always frustrated by the time it is certain to be the valve. You need to replace the valve. No one is allowed to fix a gas valve - liability - gas etc. Replace the gas valve and your problem will be solved. I am a master plumber/gasfitter and I am confident that this will solve the problem. Been there - done that.
Jun 16, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Takes long time to heat then goes from hot to cold.
I know that this is a great answer but with out being there its hard to answer you call there tech support they are great, I have had to call they from jobs before they can help
Phone Support:
Electric Product Technical Support: 866-330-2729
Feb 03, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water Heaters Logo
411 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
