Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Canon camera utility won't open on my Mac. I have un and re-installed. The laptop seems to recognize that a camera is plugged in but won't display the camera on-screen to allow upload of photos
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Posted on Nov 19, 2014
cammedic
  • 667 Answers
SOURCE: Camera not communicating with new computer
I think that Canon has an update, there are differences between Panther (10.3) and Leopard (10.5) Check here at CanonUSA
Posted on Jan 27, 2008
SOURCE: Unable to download photos from Canon 350D
when downloading from my EOS 350D I get the message
'Camera launcher exe has stopped working'
I have Vista Home Edition
I am getting desperate to find a solution!!
Posted on May 04, 2008
SOURCE: canon powershot sd 750 not uploading
Canon PowerShot SD1100 IS -- Only recognized by PC when turned on and In Playback Mode. Then works fine.
Posted on Oct 30, 2008
SOURCE: My XT will not connect to Vista.
Well, that worked perfectly. Turn on your Rebel XT camera and under Menu then Tools go to Communication and set it to Print/PTP. Thank you to all you very smart people!
Posted on Jan 08, 2009
  • 8 Answers
SOURCE: i have a macbook and i connect the usb cable to
the Mac normally recognizes the camera and launches iPhoto.
Try launching iPhoto, then plug in the usb cable. Make sure the connections are tight on the camera end of the cable.
Posted on Apr 23, 2009
Mac book wont recognize my cannon elura 100
try the image capture utility. I hooked up my Canon XSi and thought the same problem (bad interface or bad cord) when it was simply not setup to open a program. Canons are notorious for forcing you to use image capture utilities on both mac and pc.
Jun 07, 2009 | Apple MacBook Mac Notebook
Switched to MAC - have EOS40D and SX100 - will not download SX100
Yes, you need to install the SX100 driver software as well. I wouldn't overwrite older versions of the Canon software, though, so do a selective install if you can.
Feb 21, 2009 | Canon PowerShot SX100 IS Digital Camera
Macbook is booting up, with sound but no display
Start up from the OSX CD. (Hold down the 'C' key during start up). Run 'Disc Utility' from the 'Utilities' menu. If the hard drive is recognized by 'Disc Utility', select the drive in the left hand column and run 'First Aid' to repair ant problems.
If the hard drive is not recognized or 'First Aid' fails to repair the disc, you will need to format the drive or even replace it and re-install OSX.
Jan 08, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Mac does not recognize my Canon HV 30 DV when i connect the FireWire.
I've been around the block with this for days, including a fresh installation of the software on my MacBook Pro. Sigh.
Here's what seemed to work:
1) Reset Vixia HV30 (tiny reset button behind the battery). Did not change any settings on the camera after that.
2) Installed Canon's software that dropped some canon-related files in Library/Quicktime folder.
3) Opened new iMovie 6.0.3 and Final Cut Express HD 3.5.1 projects (a) FCE (using Easy Setup in FCE) to Apple Intermediate Codec 1080i60 (b) iMovie 'HDV 1080i'.
4) Connected 4-pin --> 6-pin firewire cable out of the camera to a bus-powered external drive and from the drive, firewire 800 --> firewire 800 --> MacBook Pro 10.5.8.
This was a last-ditch, Hail Mary effort. It worked, and the camera showed up in the System Profiler firewire window, too, whereas it had not before all of the above. Still does not show up when hooked directly from the camera to the FW 800 input, but at least I can capture now.
Oct 18, 2008 | Canon VIXIA HV30 DV Camcorder
Canon CanoScan LiDE 60 not recognized by iMac or Mac Powerbook Laptop
Is the scanner detected in Apple System profiler? If so, what applications have you tried to access the scanner from?
Jul 04, 2008 | Canon CanoScan LiDE 60 Flatbed Scanner
Jan 27, 2008 | Canon EOS-5D Digital Camera
Transfering video to Mac
I believe that camera only works with firewire. You might want to check with Canon to see if there is compatibility problems with Macs. I know it works on Windows computers.
Jan 17, 2008 | Canon ZR800 Mini DV Digital Camcorder
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Dec 27, 2007 | Canon PowerShot A560 Digital Camera
EOS400D Utility Error
hi
check on the canon website for updated software to install the utility
often new versions are released and are freely available to download off their site
look for your camera model and check the links to download
some new cameras sold today still dont have the applications shipped with the unit
the website is the best place for the latest versions
otherwise use a third party application to transfer the images
picasa by google does a good job too
D
Sep 28, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
