Question about Toshiba Satellite A305-S6857 Laptop
My Toshiba Satellite A305-S6858 keeps restarting when it is plugged in to charge. I have no problem running the laptop on battery Also, when plugged in and I boot in safe mode the problem does not occur. Only when I am running in normal and the power cord is plugged in. I need help.
On the computer manager, go to the device manager and disable the processors. It worked for me like a charm after several attempts to restore it to original settings and formatting the hard drive. It doesn't affect performance, it seems to be more a failure of the drivers than the hardware.
Posted on Aug 19, 2012
My Toshiba A305-S6858 keep restarting automatically frequently when the power cord is plugged in. It seems to be working fine when run on battery, but the battery has suddenly giving very less backup of max 25 mins when fully charged. When removed battery and used only power cord, it fails to boot or hangs or restarts quite often. What could be the cause?
Posted on Apr 14, 2011
    Scholar:
  • 115 Answers
Hey there,
That sounds annoying :). If it's the case, that it restart when it is in normal window, updating the BIOS is not applicable. Installing BIOS update is very risky, your charger must be connected and the process must not be interrupted. Interruption will cause the motherboard to fail. If the problem just started, you may try the system restore in safe mode to go back in the last working condition of the laptop. If this will not resolved the problem, you have to do the system recovery. You need to back all of your files, once you do the recovery everything will be deleted and it will just load the factory settings.
Link for system restore procedure- http://bertk.mvps.org/html/restoresysv.html
Link for system recovery- www.mytoshiba.com.au/support/items/faq/71
Hope it helps you.
Posted on Mar 14, 2011
    Problem Solver:
  • 5 Answers
This problem is typical of a failing NEC/TOKIN Proadlizer, which needs to be replaced. How it can be done is shown here: http://gs138.photobucket.com/groups/q251/S1BXDWUERU/
Posted on Jul 29, 2012
Change your power scheme from laptop to "Always On"
Posted on Jun 13, 2012
  • Gaston Jun 13, 2012
  • 3 Answers
Try to do what you're normally doing when you're trying to boot into safe mode, but instead, choose "Last Known Good Configuration." Also, try running the computer when it's plugged in, but the battery is removed. If this works fine, then try and run the computer with both the battery and the power outlet and see how that goes.
How to download Toshiba Satellite A305-S6858 Windows Vista device drivers to disk
You can download the drivera to your computer and then copy them to disk or USB memory stick.
You can download the device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Sep 01, 2012 | Toshiba Satellite PSAG0U-02D00M Notebook
I have the Toshiba Satellite A305-S6857, and lately whenever i play music, or watch movies, or videos online the sound and video will skip or become delayed a couple seconds as if the computer is...
you do have something else running in the background and its using the internet, probably spyware or malware. run your anti-spyware program and check, if you don't have one, you need to try "malwarebytes" or "spybot" they are free programs
Mar 19, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
WEBCAM DRIVER OPEN FAIL. Toshiba A305-s6858 satellite Using Vista 64 bit
i had a dialog ''close the other video streaming application to start video'' - what should i do?
Apr 23, 2010 | Toshiba Satellite PSAG0U-02D00M Notebook
Web camera on satellite a305-s6858 won't open
everytime i have seen that it is not software related. check if it is under warranty. typically it is the webcam cable that fails.
Nov 06, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
I instaled windows 7 today in my Toshiba a305-s6858 but I cnn't find a driver for camera asst for wondows 7
Check "the list" at www.windows7.com If yo are there ... 7 is suppose to run it ... if it is not, contact the device manager and demand a driver for 7.
Oct 30, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Hi, I have Toshiba Satellite (Fusion Finish) A305-S6858 special edition which my uncle brought for me from the US lasy year. But the picture quality is genrally poor. How can I correct that?
You have not installed Graphics/Video drivers on your laptop. Go to toshiba website and try downloading the drivers, or go to www.intel.com if your system is intel processor.
Regards
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Drivers
Toshiba satellite A305-S6858 XP Drivers
all driver tested. all driver worked.
http://uploading.com/files/d6f2c6f5/toshiba305-S6858-XPdrive­rs.rar/
Jun 01, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
A305-S6858 Laptop screen replacement
please reference follow steps to disassemble LCD screen
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/remove-replace-LCD-screen-inverter-1.htm
be careful all small cable like KB top cover LCD cable and inverter cable.
hope help you fix it, please take a rating let me know huw much helped you thanks! keep in touch your question.
May 21, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Toshiba laptop hard reset needed
check in your my computer
see its there will say restore or recovery
can also right click my computer properties
you'll see retore in there
Jan 17, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A305-S6857 Laptop Logo
2,096 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
