Question about Frigidaire FDB520RH Builtin Dishwasher
My washer runs a very long time and doesn't dry the dishes but the light comes on
  • Frigidaire Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 14, 2011
When i turn on the dishwasher and cycle has run and its finised . the dishes come out cold and wet
sounds if the drying cycle isn't working , most washers use a small blower fan to move air thru chamber 2 dry dishes , these little fans do rust up over time and need replaced sometimes , id say finding fan and cking it for rust and freedom of movement is a first step in this , most times there inside door of machine
Dec 21, 2016 | Dishwashers
My clean and light wash light constantly blink, and nothing I do seems to help
try pushing the heated dry then sanitize buttons 4 times. one then the other in quick succesion. all lights should come on,, this is a test and will take about 8 min. let it go thru this and then try your washer. make sure you run hot water at your sink before you wash dishes in the future.
Jan 02, 2012 | Maytag MDB7100AWB Dishwasher
Kenmore dish washer lock button blinks and doesn't run
Hi
Thanks for using FixYa. To unlock the controls Press and hold Air Dry/No Heat Dry for 5 seconds or until the light turns off. Please revert back for more help.
Rylee
Dec 23, 2011 | Dishwashers
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
My dishes still come out wet..how do i set the washer to dry the dishes
there should be a setting or a button to turn the heat dry on and off, if it is on and dishes are not drying then the next time you do a load of dishes pay attention to the cycles, after the rinse cycle is complete the heat should come on. if not you could have either a bad heating coil or a bad relay.
Aug 20, 2009 | Kenmore Dishwashers
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Every time i was my dishes in the dish washer they come out with a cloudy film over them
you need to add some drying agent to your dish washer, it helps them to keep from being cloudy. I do not think it is a mechanical problem.
Jun 03, 2008 | Dishwashers
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
Frigidaire FDB520RH Builtin Dishwasher Logo
227 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
