Question about InFocus ASK Proxima M2+ Multimedia Projector
In Focus Ask Proxima M2+ has a squeaking noise and the image flickers. After about 30 minutes the unit goes to standby.
  • 40 Answers
Bearing on the fan is probably shot, causing the unit to heat up and shut down. Repair would more than likely exceed the replacement value of the projector.
Posted on Mar 14, 2011
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Hi. I have a InFocus dp2000x. It has no lamp. I try with a flashlight in the lamp chamber (the flashlight is battery operated) When I turn on the projector with a vga or video input, the power led start...
Projectors are designed to be used with a lamp and will turn off when there isn't one present. You would have to purchase a new lamp to use the projector.
Feb 19, 2011 | ASK Proxima Proxima DP2000X Multimedia...
Hi, i have viewsonic 1940w. When i turn it on it makes buzzing sound and after 5-30 seconds it goes in stand by mode(orange light). Sometimes screen flickers to. If you turn off monitor and on again you...
I fixed this same Viewsonic problem by replacing the electrolytic caps on the power board and re-soldering the power transformer joints. The noise is coming from the transformer, if you torque it the noise stops. Cold solder joints must have been the cause (large posts did not heat up enough during construction). The bad joints might have caused a cap to overheat too, not sure but one was swollen and leaking and after replacing them the squealing was stronger and allowed a longer running time to locate the cold joint.
Oct 23, 2010 | Computers & Internet
Flickering monitor
try changing the frequency to a higher value, (refresh rate) google for more info
Aug 28, 2009 | E-Machines eMachines Desktop PC
The image flickers on and off I have checked connections what else should I do
Is the image clear or does the image start to fade.
Is it in focus ?
What model ?
If the image is out of focus or blurry, and after a few minutes of running the unit goes out, you may have had a power surge.
Aug 28, 2009 | Acer Computers & Internet
Ask proxima m2+
lamp gets brighter & brighte within a minute & immidiately color wheel stops rotating & projector goes to standby mode. for 3 to 4 minutes again same symptom contimuously observed pls guide me which part is suspected
Jan 16, 2008 | InFocus ASK Proxima M2+ Multimedia...
Proxima DP2000x
that model has issues with the power supply board. unfortunately, there are no replacement boards.
Oct 19, 2007 | ASK Proxima Proxima DP2000X Multimedia...
InFocus ASK Proxima M2+ Multimedia Projector Logo
203 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
