Question about American Standard Plumbing
I'm making a concrete porch, do I need to lay a "footer" first?, it will be 10"x10"x3" I'll be filling in the inside with dirt, and not sure of how deep the slab should be 3in.?
  • 528 Answers
If you live in an area where it freezes for long periods of time in the winter you should put in footers at a 3 to 4 feet and even if you don't live in freeze area you should put in footers at a 1 1/2 to two feet if want the porch, As for the 3" you may as well go with what ever a 2x4 comes to and you will not have to cut the boards dow to 3".
Posted on Mar 14, 2011
How do i stop frogs from getting on my porch?
turn off the porch light or use a yellow light that doesn't attract moths and insects
they are coming there for the easy food source from the light
if there is no porch light , pull the curtains to stop the room lights from attracting the moths and insects
Aug 07, 2017 | Motorcycles
How many cubic feet in a cubic yard
3 feet x3 feet x3 feet = 27 cubic feet in cubic yard
1 bag concrete mix is 2/3 cu feet or .66 cu feet
41 bags cement mix will make 1 cubic yard
Sep 02, 2014 | Garbage Disposals
Wheelchair ramp&deck
I'm not sure what the question is but if it is related to putting wood directly on the concrete then it should not be a bigproblem as long as you use treated lumber and orient them in the same direction as the natural drainage of the concrete
Jan 09, 2014 | Garden
How do i fix a hole in my concrete foundation wall
At just about any home & garden store you can purchase a type of media to repair this. Almost like a drywall patch but with concrete mortar. Simply use a mesh tape on the inside of hole (if possible, if not u need a very thick mortar) then fill in with mortar. U may need to apply several layers, one at a time, to build up to fill void. 11_18_2013_3_15_14_pm.png
Nov 09, 2013 | Building Materials
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
Can I fill an old wood stove pipe going through the concrete foundation wall with concrete mix? It is above outside grade so wondering if i can remove the pipe, block the inside and fill it from outside....
Im not sure about what you are calling the pipe block but if the out side is above grade use hydrolic cement mix or water plug get out all loose meterial it will bond find just don;t let water get in from out side because if it freezes the ice will expand and crack the repair and over time will start to leak you may want to seal the repair from the outside with a product called water stop i think thats what its called inselx is the co. that makes it then top coat it On the inside you can do what ever works and looks good as long its not leaking from the out side it will last
Nov 21, 2010 | Plumbing
Building a suncast shed on 10 x10 patio block
IF you're speaking of the hard black plastic floors that come with thes, I'd put it directly on the patio stones. No wood to rot.
Jul 13, 2010 | Suncast 10' X 10' Storage Building
When do I need moisture control for wood flooring?
You need moisture control if laying below ground level or on concrete anywhere as concrete is porous
Jan 03, 2010 | Crafts & Hobbies
How to make a drivingway for my garage of my new house.
Hey Paul,
I'll give you the rundown. First, for a driveway, I'd have to advise using a pretty thick slab of concrete beneath the brick. The concrete part of it should be done professionally. But I live in an area with lots of rain (hence, Mud), might not be a problem where you are. Anyway, here you go:
  1. Clear the area so its smooth. Grade it if necessary.
  2. After clearing the area, set the perimeters with string or with 1x4 boards. This keeps you from going wide as you lay the bricks
  3. Get a load of sand and spread it evenly over the area. This can be done easier with two people and a long 2x4. The depth should be at least an inch. This makes leveling the bricks MUCH easier. Keep some aside for filling in the spaces between the bricks. Keep it dry too.
  4. Start at one end and start placing the bricks. As you advance, you'll be on the bricks, not the sand.
  5. Have a straight edged board handy to level them. Use a rubber mallet to tap them down. Consider the spacing between them. Use a scrap of 3/8 wood or something like that to keep the spacing consistent.
  6. As you place more bricks, get up occasionally and eyeball your work.
  7. After they are laid, you'll need to hit a home improvement place. You are looking for a glue (powdered) that is mixed with your left over sand to set the bricks. Ask someone there, they will know.
  8. You mix it in with the sand and dump it in the middle of the bricks. Then just sweep it over the entire area until the spaces are filled. Then sweep off the excess.
  9. Once filled, lightly spray water over the whole drive. This activates the compound. Once dry, you have a driveway.
If you do concrete it first, you'll only need enough sand for the space fill.
Hope it turns out great. I love brick drives.
Mike
Jan 10, 2009 | RCA 20F420T 20" TV
Plumbing Logo
82 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
