Question about Samsung Refrigerators
Only ice cubes are produced, no crushed ice. - Samsung Refrigerators
  • 351 Answers
Check the auger they alot of the time get jambed if it is free of ice and or other debri you will have to change the auger its the only thing that crushes ice.
Posted on Mar 14, 2011
Ice maker only produces crushed ice no cubes
Good Afternoon Gerald, thank you for your post!
I see that your Frigidaire refrigerator is only dispensing crushed ice not cubed ice. Your solenoid (which tells the dispenser crushed or cubed) might be frozen. You can defrost the solenoid by disabling power from it for at least one hour and then restoring power. If you continue to experience this issue you may need to have the solenoid replaced or the control panel and I would suggest having a professional technician out for proper repairs. Good luck with your refrigerator! -Matt
Apr 16, 2016 | Frigidaire Refrigerators
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | GE Refrigerators
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Apr 15, 2015 | Crosley Refrigerators
Crushed Ice Only?
hi there, sounds like you have high water pressure, have a look in your ice bin, if ice cube appear large, they will not pass through the teeth in your ice bucket, you will to go to a plumber store and pick a pressure reducer,this will slow down the pressure
cheers
Nov 17, 2012 | Samsung RB1955 Bottom Freezer Refrigerator
The ice maker is working but it is only producing crushed ice?
i think you mean that the crushed and cubed ice is not working . / if so the problem is in the pc program board . .. mm
Jul 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Can not get cubes from the front, just crushed ice and water?
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 23, 2009 | GE Hotpoint 25.0 Cu. Ft. Side-By-Side...
Kenmore side by side will only produce crushed ice and not cubed
remove the ice bucket inside and clean any clogged ice from inside the dispenser.
Apr 29, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
168 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
