Question about Dell Dimension 8300 PC Desktop
I am trying to re-install windows xp on a DELL dimension 8300 but it does'nt boot it can go to the BIOS and everything but it say Boot.mgr is missing
  • 1 more comment
  • AddictedGeek Mar 14, 2011
    It Dont recognize the Window CD
    i Try it on another computer and it works perfectly i also change the CD-ROM and it didnt work
    i try it on another PC and it work Perfectly i also change the CD-Rom and it didnt work
  • 32 Answers
To reinstall Windows, insert the installer disc, power off the machine, then power it back on while pressing F9 or F12 (the first screen should show you which option to push for "Boot Menu" or "Boot Options"). Once your at the boot menu, select the CD/DVD drive and follow the instructions on the screen.
Posted on Mar 14, 2011
  • 55 Answers
You should use the bootable Windows XP CD to start the installation.
To do that, you must first enter the BIOS in the Boot Options select the DVD drive as first (so that it will boot from CD/DVD first, instead of the hard disk). Save and Exit, insert the bootable Windows XP CD in the drive and when prompted to do so, "press any key to boot from CD-Rom".
Hope the above helps.
    Hey! i already did that but what happen is that it doesnt recognize the Windows XP CD =/ i try changing the CD and the DVD/CD Drive and it still doing the same thing
  • Dimitris Panokostas
    Dimitris Panokostas Mar 14, 2011
    Does the CD you have actually work? Is it an original Windows CD or just a copy? Have you actually booted from it before (even on another computer)?
    If not, maybe it's the CD's fault, in which case you should locate another, working Windows XP CD.
    If however the CD is proven to work, then it could be an issue with your CD-ROM drive instead. You could therefore try to get hold of another drive and repeat the process...
    Hope that helps!
Boot mgr missing message
I could have told you you were loading Windows 7 by the symptoms. Try running a Malware program with a register edit-register function in it. If you are switching from XP Pro. you will need to clear your register and all command and drive to . Set BIOS to boot from DVD/CD first then set the hard drive to boot second. Windows. Also if you have access to another computer ask microsoft for tech support.
Apr 01, 2012 | Compaq Presario 5000 PC Desktop
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
How do I reformat a Dell dimension 8300, it will not do anything after inserting the operating system disk
You need to make the DVD drive the first bootable device.
F2 on boot up should take you into the bios, it should say on the first screen as you boot what key takes you into the bios/setup.
Change the boot settings to allow the dvd drive to boot first.
It should now say press any key to boot from cd/dvd when you put your installation disc in
Sep 04, 2010 | Dell Dimension 8300 PC Desktop
I have a Dell Dimension 4600. I need to re-install Windows XP Professional. The PC won't boot from the CD-ROM. When I choose F12, then Boot from IDE CD-ROM, the PC boots directly to Windows. how can I get...
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
Oct 29, 2009 | Dell Dimension 4600 PC Desktop
I would like to reboot my dell dimension 8300
1.Press Start> ShutDown> Restart and OK. It will power down and restart (reboot).
If you cannot do that (for wathever reason), press the Power Down button for about 10 seconds. The computer will turn off. After that you will be able to turn it back on again.
Hope it helps
Aug 22, 2009 | Dell Dimension 8300 PC Desktop
HELP
ok
For that check in bios that first boot device is your cd or dvd rom.
When you power up the computer pressF2 or "del" key to enter in bios then go to boot option then set first boot device as your cd or dvd rom then save settings then exit.
then check.
Also you can boot your cd or dvd with F12 key
Press F12 when you power up then select your cd or dvd for boot.
Please rate solution if it helps you.
Thanks for using fixya.
Jul 18, 2009 | Dell Dimension 8300 PC Desktop
Dell demension 8300 pc
make sure boot sequence is cd-rom first and possibly disable hd
Jun 22, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
PC will not boot from CD drive
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
Boot Manager
You will want to do a Windows Recovery Environment Startup Repair, follow the instructions below to fix this issue:
To access the WinRE using the Vista install disk:
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
The following options are available in WinRE:
  • Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
    After attempting to repair the system it will display a Startup Repair diagnosis and repair log with the different Test Performed and the probably root cause.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
Dell Dimension 8300 PC Desktop Logo
172 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
