Hi y'all! I recently aquired set of Neptune W&D. Washer is a TL and has 2 problems: 1. When washer goes into the spin mode, it sounds like a freight train going by. VERY LOUD...like maybe the bearings in the motor are shot...heavy metallic growling/grinding noise. 2. Now today it only spins at about half speed.
  • 351 Answers
Them are junk...Lol sorry but yes in the back where the pulley is there is a bearing and you have to replace the whole thing a 500$ part
Posted on Mar 13, 2011
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
I start load of wash, with setting of Max Extract being ON. Clothes come out very wet
I would put the machine in Service Mode with that Wet Wash Load in the wash basket and do a Quick Spin Test on page 14 of the Service Manual and record the fastest RPM that the wash basket will pin up too.
If you don't have the Service Manual Google this Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
If you want help post your issue in that Maytag DIY froum and I will help you......or stay here and see how it's goes.
Mar 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag toploader Neptune washer stops with 10 minutes left on quick wash and code "uc" on LED. There is a little water left in bottom of tub and cloths are soaked. It does fine until the spin...
It sounds like the Outer Bearings are going due to a leaky Tub Seal. Bothe can be repaired and have done on this site. This site has no way to reference past post to machine issues.
I have helped owners of theFAV6800A and FAV9800A machines here but I prefer a tru DIY site.
I no longer post on this site no way to post a Sticky for machine issues.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a top loading Maytag Neptune TL that will not drain. When you start the machine it runs for a few minutes & then shuts off and the time on the screen freezes. I think there is possibly an issue...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL - When rinsing the basket slams into side of machine -
If it’s a FAV6800A or FAV9800A let’s fix it.....
See this post Clutch Fix for a step by step process to maintenance the clutch or replace.
The machine is shutting down with dc or UC unbalance error code correct?
Rich
Apr 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't spin
You need to check this part of you machine:
Test the lid switch
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the drive belt(belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Check this parts this are the some cause to not spinning.
Dec 10, 2009 | Maytag Neptune Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Neptune TL won't spin, continuously beeps through spin settings
if water remains in the tub it will not go into the spin cyc something in the pump clear it and try again
Aug 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
