Question about Canon Cameras
I was shooting a wedding and the 580 EX II was getting a work out as it usually does in darker than usual spaces. It worked for about 4 hours just fine, but then the flash started overexposing and then not flashing at all. I replaced the batteries in the flash and the turbo charger battery pack, but it didn't help. I had to use the on camera flash for the rest of the evening. Does anyone have any idea what happened?
  • Canon Master
  • 3,083 Answers
This sounds like an electrolytic capacitor in the external flash failed, and needs replacement. They're critical components of the flash unit, and do go bad in time. Usually replacing them restores the unit to a "new-like" state, and will revive the unit for years.
Another problem could be occuring with the camera circuitry, but not likely.
You can change out these caps, and they are usually available at Radio Shack.
Wish I could offer a simpler solution,but this is what I think is happening.
Good luck,and hope this helps.
Posted on Mar 14, 2011
Does the ste2 transmitter work on a canon 5d with a 58011s speedlight?
This is an IR transmitter and as long as your EX 580 II works with IR you'll be OK
Jul 13, 2014 | Canon Eos Cameras
Can i use a Canon Speedlite 580 EX II for a canon 550D?
Yes. The 580EX II will work with any Canon digital SLR.
Nov 12, 2012 | Canon Speedlite 540EZ TTL Flash
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580 EX (mark 1) 6 years of continuous use - single flash, multiple flash & continuous burst - with rechargeable batteries. All is well, until recently. Now recharge time has quickly...
The capacitor (neck) is no longer hold a charge or charging circuit is going out on a extended breaks.
Save your money and buy ATG's Godox TT685c.
If you buys two, then you got ATG wireless radio ETTL II flashes.
It would cost over $1,000.00+ USD to buy two Canon 600EX II-RT just to do the same with two ATG's.
Apr 25, 2017 | Canon SPEEDLITE 580EX TTL Flash
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Dec 27, 2008 | Canon Speedlite 540EZ TTL Flash
Photos are not sharp
I would look beyond the camara and suspect that the computer is tired or overloaded. This would be a more logical point of defining the trouble and cheaper than suspecting your fine camara and expertise. If you still think it is the camara take it off the auto focus for a few weeks and see if you still get problem shots. If So take the puppy in for an overhaul of the timing shutter mechanism. It may just have a fuzz ball or rather hairball problem that only momentarilly and intermitintly snags. If it is not the auto focus then how about a different computer program choice?? Photo files eat up a lot of space and unless you have one computer that is totally dedicated to just the storage fixing and printing of the pictures you may simply have a RAM vs PIXEL problem. Try off loading some onto disc for storage instead of keeping them all on the machine. If they print out better in quality than you see on your screen then it may be your monitor that needs to be reset to handle fine detail in the contrast settings. You may have to upgrade this equipment, which I would for the TAX BREAK.
Nov 21, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Amperege of 580 EX-II
Interesting Question!
The rating in milliamps is a matter of battery capacity and charging rates. The higher the better as you will get more flashes per charge as long as you have the correct charger to match the batteries’ capacity and use the correct charging times. Aside from this issue of duty cycle between charges- this has no effect on the power of the flash unit as to output. This cant burn out or damage the circuitry.
The issue here is VOLTAGE. Most AA alkaline batteries provide 1.5 volts. Most rechargeable AAs provide 1.2 volts. We are looking at a voltage differential of 1.2 volts (a 20% deficit) if 4 batteries are required. This MAY cause slower recycling times in order to attain a full charge for each shot. In SOME units that can cause a bit if overheating due to strain on the step up circuitry.
It so best to check with the manufacture or distributor of you flash unit before purchasing you rechargeable batteries and charger. If you units have a built in charging circuit this can definitely be problems if there is a mismatch in charging rates and voltage. If this is the case be sire to check your manual or with the manufacturer or distributor- there must be a list of compatible batteries.
Ed
Jul 08, 2008 | Canon SPEEDLITE 580EX TTL Flash
Canon speed lite 580ex 11
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
Jun 30, 2008 | Canon SPEEDLITE 580EX TTL Flash
Cameras Logo
188 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
