Question about Bachmann Ho Iron King Train Set
My son has an Iron King Train that the locomotive just stopped. It was stop/go for a while and now it doesn't run at all. Any ideas on what to look for?
  • 161 Answers
First: clean your trackSecond: clean your wheelsif that fails, call 1-800-356-3910& speak with Bachmann Parts & Services to find out if your
locomotive need to be sent in for repair.
Posted on Jan 28, 2013
Changed batteries in Brio train (mighty red locomotive) and still does not turn on. It was used for about an hour and stopped working abruptly.
I had the same problem with one old locomotive. There are three things to check:
  1. the main power slide switch is set on the rigth position
  2. on the bottom of the loco, there a small red bump, it is perhaps blocked in the pushed position
  3. this one was the solution for me. Dismantle the battery cap and make sure that both metallical parts are in contact.
Dec 24, 2014 | Brio Mighty Red Locomotive
Locomotive moves then stops
If your locomotive continuously starts then stops, when prodded with hand/finger repeats process. Then most likely, first check your electric connection for a loose connection. If everything looks ok, check wheels on locomotive for dirty wheels, then check track for dirty track.
Nov 10, 2013 | Kato N Scale, Amtrak P42 Superliner Train...
I have an 1985-1986 talking silver rail express train set and it will move just a little ways and then stop. Has something happened with in the gear system?
My son recently disassembled one with the same symptom. He found one of the small gears in the drivetrain had split -- causing it to bind and limit motion to a inch or so. It's been in the family 25 years, but we elected to junk the locomotive :(
Nov 09, 2013 | Echo Toys
How is Bachmann's Blue Comet's locomotive powered. We were just given a set. The tender & each car take 1 9v battery but I know there must be more.
The backhead on the boiler inside the cab of the locomotive opens up and you install cell batteries into the boiler to run the locomotive..
Aug 25, 2013 | Bachmann Big Hauler Radio Controlled Train
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
Kato locomotive doesnt run. Goes for a short time with spray of contact cleaner then stops
That means that your track is dirty. Your locomotive is picking up dirt from the track, which builds up. on the wheels. Use a track cleaner NOT alcohol... the alcohol does leave a residue on the track after it dries.
Jan 10, 2010 | Kato N Scale, Amtrak P42 Superliner Train...
Locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Dec 12, 2009 | New Bright 181 Toy Christmas Train
Brio Mighty Red 512 - Battery help
Easy to do. You'll find a small phillips screw located at the bottom of the black smokestack. After unscrewing it, lift up the entire front black part and you will see two AA batteries inside the body of the locomotive. Careful not to strip the screw when replacing the black smokestack part, as it is the only thing holding it down!
Sep 11, 2009 | Brio Mighty Red Locomotive
Bachmann Ho Iron King Train Set Logo
125 people viewed this question
Top Bachmann Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
