Question about DEI Valet Keyless Entry System
Hi i have a dei rpn491 automate car immobiliser with central locking problem is that the red light on the remote stays on we changed the battery but still does the same thing this morning i used the vallet button to start the car but i need so advice on what the problem could be with the remote thanks ray
4 Suggested Answers
  • 34 Answers
SOURCE: remote starter will not start vehicle
first thing i would try is locate the main box for auto start. usually it is under dash on the driver side when installed. then find the lage or hrness with the most wires going to it and unplug it/wait a few min. then plug it back in. sometimes the unit will go into a security mode. this will just reset it. if this doesn't work then let me know
Posted on Jan 09, 2009
  • 13 Answers
SOURCE: My valet remote control RPN491 Starts vehiclr and
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Posted on Oct 29, 2009
logosc75
  • 625 Answers
SOURCE: My DEI Valet system will not operate the door
You failed to mention the year/make/model of the vehicle so, I will assume that there existed some sort of door lock/unlock/alarm disarm bypass module in your vehicle that is no longer functioning. There is no simpler fix then either resetting the module or, remove and replace it.
Posted on Sep 30, 2010
My C Class immobiliser seems to be stuck. the red and green lights come on the rear view mirror. A few times disconnecting and reconnecting the battery has helped reset the immobiliser, but it is hit and...
Hello Abdul,
I had this problem and the solution is rather strange.... Change the battery in your remote key for a brand new fresh one and see if this solves the problem. Apparently, when the lithium battery is low, the central locking will continue to work but the immobiliser disarming circuit cannot decode the signal.
Jan 01, 2011 | 1996 Mercedes-Benz C-Class
Hi what tupe of starter i should purches for my car i have santa fe 2002
It really depends on what features you are looking for. I installed Audiovox for 12 years and DEI for 8. I like the DEI much better. The Audiovox always had problems with their remotes and would break down. DEI remotes last much longer and all the options are better on it too. They are the leaders in the field.DEI is the makers of Viper and Python as well as automate.
Nov 12, 2010 | 2000RS-M Remote Starters Manual...
Toyota hilux surf immobiliser problem.
My KZTE Double Cab Bakkie (Utlity vehicle) comes with a Factory fitted central locking system
Yesterday the Remote would not un-lock the vehicle. The battery in the remote has been checked and seems ti be OK. I managed to open the vehicle (coat hanger through rubber on door method), when opening teh door the alarm went off (hooter etc). I placed the remote in the de-activating housing but it did not de-activate the alarm. I am now driving around with the flashers going for 20 seconds or so every time I open a door, but teh vehicle drives (I took out the hooter fuse to keep my sanity)..
Please help
Regards
Anthony
Dec 20, 2009 | 1998 Toyota 4Runner
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Sep 11, 2009 | DEI Valet Keyless Entry System
I have a DEI 471T remote start/lock. The parking
There is a white wire coming from the alarm, there should be a blue 15 amp fuse in that wire, close to the brain for the alarm. It sounds like you have blown that fuse.
Aug 10, 2009 | Directed Dei Valet 561r Remote...
Imobiliser problem
If im not mistaken,your car should have an alarm reset/override.Below the steering column,on the dash should be a slot where you put your remote transmitter to deactivate the alarm.If that works,you then need to have your remote checked and coded by a vw dealer.Good luck.
Jun 16, 2009 | 1997 Volkswagen Golf
What fuses does it take? Have it in my car but there are missing fuses also have other dei products in my car that are wired but missing fuses. Please help!
I'm still digging but I have some info for you. DEI- 530 is a Window automation system. DEi- 529 Is a window roll up module. DEi-520 is a battery back up.
May 04, 2009 | Honda Civic Cars & Trucks
Immobiliser problem - 94' Golf Mk3 GTI 2lt 8 valve
just unplug the immobiliser unit. its behind the glove compartment for rhd models.
Mar 15, 2009 | 1997 Volkswagen Golf
Car wont start
IS THE RED LIGHT THAT IS STAYING ON THE BATTERY LIGHT? IF SO IT COULD BE AN ELECTRICAL FAULT, AND IS NOT FIRING UP THE ELECTRIC FUEL PUMP
Mar 13, 2009 | Acura CL Cars & Trucks
Peugeot 307 hdi 2002 5 door will not start
Check the fob battery because if the battery has gone then you can't immobilise the car immobiliser which in turn doesn't let you start the engine however it cranking. open the bonnet and remove the clips of car battery for a good 15-20 minutes and put them back and check your remote key and try to start your car. If nothing happens then let your car diagnosed by a experienced mechanic who is able to read out the ecu codes.
Aug 20, 2008 | 2005 Peugeot 405
DEI Valet Keyless Entry System Logo
119 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
