Question about Toshiba Televison & Video
Need code for toshiba flat screen tv - Toshiba Televison & Video
    Top Expert:
  • Toshiba Master
  • 75,471 Answers
Hello
Three digit universal remote code for Toshiba are:-
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit universal remote codes for Toshiba are:-
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
NB: Switch OFF and switch ON your TV, with its front panel power control switch each time before trying an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Mar 14, 2011
Need the code for RadioShack Remote control tv/dvd 15-302 to set up Toshiba Flat Screen TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 17, 2016 | Toshiba Televison & Video
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
The TV is a Toshiba flat screen the remote is a Toshiba CT-9854I need the code so my TV will work with an antenna
Antenna reception is no longer available since the nationwide conversion to digital signal transmission.
Apr 01, 2015 | Toshiba Televison & Video
Can you help, i have a toshiba tv (quite old, not flat screen) and i broke the remote control. I now have a [URC22S Universal Remote Controller] and I'm having a lot of trouble getting it to work
Please provide more details. What do you want to know. Setup codes? If so, check this site. Setup code list and setup proceedings to many popular brand remote controls are given.
Apr 22, 2013 | Televison & Video
Fine line down centre of screen
call Toshiba ASAP if you still have warranty, the TV needs to be replaced. The line will get worse!!
Feb 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Remove Base from Toshiba Regz 42RV530U
I bought this LG flat TV at Circuit City last week. TV is okay, but I was trying to hook up my portable DVD player and I can not make it work. I can hear the sound that coming out from the DVD but theres no picture from the screen. I believe my connection is correct, because there is the color coding which is red, yellow and white which you just connect at the back of the TV and at the DVD player.
Can anyone help me to figure out the problem. thanks a lot
Jan 31, 2009 | Toshiba REGZA 47HL167 TV
Universal remote control codes for toshiba t.v. amd syphonic vcr
have a jensen universal remote need codes for toshiba tv vcr combo lost book.
Jan 19, 2009 | Directed 434MHZ Remote Control
Tv remote for 32 inch toshiba flat screen tv
tohhiba codes 062,064,085,229,231,385. for cable tv converters use 019.
Oct 22, 2008 | Toshiba 32AF42 32" TV
Toshiba Regza 32LV67U remote control code CT-90275
my lcd screen toshiba is broken, what can make??
Feb 23, 2008 | Televison & Video
Televison & Video Logo
1,014 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
