Question about Dryers
I have an LG DLE2532W and the check filter light keeps blinking even though it is clean and the dryer won't work what could be wrong?
  • 351 Answers
There is a thermostat or safety somewhere on the dryer where the filter is and it probably is dirty or bad.
Posted on Mar 13, 2011
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
Not getting hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 26, 2011 | LG DLE2532W Electric Dryer
My LG Tromm DLE2532W dryer is not producing any heat
heatman101./,'
May 15, 2011 | LG DLE2532W Electric Dryer
Wouldnt dry no heat, checked dryer hose, it was full of wet lint, we cleaned it out but still no heat?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 03, 2011 | LG DLE2532W Electric Dryer
Dryer gas will not light pilot lite dead how do I restart it
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | LG DLE2532W Electric Dryer
Dryer is not heating
heatman101
Nov 07, 2010 | LG DLE2532W Electric Dryer
My LG dryer is electric, model# DLE3733W The heat doesn't work, all lights on the panel come on according what I set it at. I can then unplug the power supply and plug back up and the heat works until the...
heatman101
Nov 06, 2010 | LG DLE2532W Electric Dryer
DLE2532W Dryer
I had the same problem. Really glad I came to this site. Had already tried to clean out the filter area. What really worked was unplugging and resetting the computer. Everything seem fine now.
Mar 16, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
218 people viewed this question
Top Dryers Experts
