Question about Garden
Skylink 318k remote garage door opener doesn't open door. Beeps according to the manual as it has always done but backlight no longer works. Is that the problem? Is only option to replace?
    Master:
  • 403 Answers
As far as the backlight, dont worry about it. You need the find the program button on the opener itself. With the door up, push the hard wired button,, on the opener, and the remote pointed to the opener, button at the same time to close. This should reset the remote..
Posted on Mar 14, 2011
Setting garage door opener
You should be able to press the button on the receiver and then press the button on the remote if the batteries are good. The skylink group can be found at skylinkhome.com Thanks BB
Apr 21, 2010 | Skylink Group Skylink Door Window Sensor...
Garage Door Remote
find attena and point it to your door if this does not work try adding a piece of wire to attena and making it longer also always check batts...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a skylink 318r keypad with receiver to open my overhead door but dont know code as sellers of the home didn't leave this with - how do you reprogram both transitter and receiver?
keypad is model 318K
receiver is model 318R
factory setting for keypad PIN is 0000 #
there is no master reset code
you must have the current code to reset the PIN
if you hit the correct code on the keypad followed by the # key - you will get three beeps.
to change the PIN: (current PIN needed)
enter current 4 digit PIN then *
enter new 4 digit PIN followed by *
reenter new 4 digit pin and *
if accepted - backlight will flash and will sound one long beep
takes 2 CR2032 button cells for keypad
you could sit in a chair one night and start at 0000# then 0001# etc until you get three beeps
then use above procedure to change to your desired code
good luck
Jan 29, 2009 | Locks & Locksmithing
My sears garage door opener wont open or close the door
If you can get access to the back of your motor assembly on the ceiling and look where the wires are connected there should be a slide button that will have a list that will have you set the main unit to a position that will allow you to accept new remotes or reprogram for lost signal to existing remote. If all else fails there should be a phone number you can call listed on the unit and they can walk you through.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener
I just found the solution for my 'ancient' Sears garage door opener, model # 139.655000, and I figured I'd share it.
There's a separate radio module, wired to the main opener. This module is small, has a short wire/antenna, and plugs directly into an outlet.
There's a manual open/close button on this module (I didn't realize this until I got up on a ladder). This button is also a removable cover; underneath it is a "smart actuate" button -- this is your learn button.
What I did was: unplug the radio module. Pry off the cover. Plug the radio module back in. Hold down the button on the remote. Press the "smart actuate" button. This programmed my remote successfully!
Jul 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
When I key in the code the garage door closes, but when I key in the code to open the door, nothing happens It is actually a Skylink garage door opener but unable to find in the selection list
MANY UNITS NOW HAVE A ONE BUTTON CLOSE FEATURE. THIS WILL CLOSE THE DOOR WITHOUT PRESSING THE PROPER CODE.
HOWEVER, IT WILL NOT OPEN THE DOOR WITHOUT THE PROPER CODE.
SOUNDS LIKE YOU HAVE A REMOTE THAT WILL SEND A CODE AND CLOSE THE DOOR. IT MAY NOT BE ABLE TO BE PROGRAMED TO OPEN THE DOOR. YOU CAN GET AN EXTERNAL UNIVERSAL RECIEVER IF CHAMBERLAIN OR LIFTMASTER ARE ON THE LIST THAT WOULD WORK.
HOPE THIS HELPS
Jun 29, 2008 | RCA Universal Remote Control
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
