Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
It turns on by itself and squels, but if i key the mike it shuts off. it seems to be receiving when it's in the off position. ????
  • 391 Answers
Hi possible solution rewire the microphone or buy new one to suit radio
Posted on Mar 19, 2011
Microphone won't turn on
When you say "turn on" the SM58 does not normally have an on/off switch on the mike. Does yours? If so, bypass the switch. Did you try different cables or another mike on this one's cable? The SM58 is a very rugged mike but can be damaged. I'd make sure all cables, connectors, and such are good before suspecting the mike itself.
Oct 26, 2010 | Shure SM58 Professional Microphone
Won't turn over
if you have an ohm meter test the starters positive lead pole to the starters housing. if continuity is shown the starter is at fault
May 26, 2010 | Ariens 34 In 344 CC Briggs Stratton...
After starting sub. can not turn key to off position. Will not shut down. Had to pull ign. fuse and disconnect battery. whats up
Either gear selector is not in park, or the gear lever itself is loose or out of alignment, and the park sensor is not working. If transmission lever is not in park, you cant pull the key out. On most cars, the key will return as far as the I position, shutting off the engine, but not allowing key extraction.
Nov 16, 2009 | 1993 GMC Suburban
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
I just hooked up an aftermarket cd player in my truck, I've double and triple checked the wiring and everything is correct yet when I shut my key off the radio doesn't turn off. What can I do?
Hello ron_bgsu,
Either the "accessory" wire is always on or the KD-G120 itself is faulty.
Use a voltmeter to check the wire you have connected to the RED wire coming from the CD player wiring harness. There should be voltage only with the key on or in the accessory position. If there's voltage on it with the key off, it's either defective or the incorrect wire. If the wire tests OK, the problem is in the receiver.
Hope this helps.
Jun 12, 2009 | JVC KD-G120 CD Player
Icom706mk2g turns off on transmitt
I have a few ideas on this. I think when you key up something is shorting to ground or drawing down the power supply enough that the logic (ie the control circuts) shutdown. that being the case I suggest checking the mike for shorts then the the relay that toggles between transmit and receive and if thats not it. I suspect the power supply is failing. I wish there was a simple solution however as I see it your going to need a meter (DMM) and the schematic.
I found this link hope it helps you.
http://www.geocities.com/k3xf/ic706.html
good luck
Rob
Dec 10, 2008 | Radio Communications
Seccurity light staying on car starts and shuts right off gas gauge shows empty
Hello You can try resetting the security system by turning the key on and leaving it in the run position for 15 to 20 minutes, and then just start the truck don't turn to the off position until you have started the truck. after that all should be fine, And remember use the key with the chip on it too. Hope that gets you up and running. Thanks for using Fix Ya bear001
Jul 17, 2008 | 1999 Chevrolet Blazer
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
77 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
