Question about Hayward SAND FILTER, PRO SERIES
We have a hayward 244t sand filter. I was trying to learn how it works. I was trying to vacuum the pool but all the trash is coming back into the pool. What do I do?
When pool is running on filter water comes out of backflush hose
Posted on May 23, 2012
  • 640 Answers
For regular vacuuming, these pool filters should be set to the "filter" setting filter control valve. However, if you have a heavy load or the debris seems to be coming back into the water, you can try vacuuming with the filter set to the "waste" position. This will bypass the filter and vacuum directly out to waste.
Posted on Mar 15, 2011
How come algae is leaking back into the pool? I have a hayward sand filter pro series.
too small and passing through sand try a scupe of DE between backwashes better when vacuuming alge go to waste keeps it out of your filter now super shock to get rid of algae in filter or change sand
May 30, 2014 | Hayward SAND FILTER, PRO SERIES
I have a S-244T sand filter and I am noticing that my water level is going down about 3/4
When the pump is running is water discharging from the waste pipe outlet?
If so then the selector valve that switches the pump outlet to waste, backwash, filtering etc. is faulty.
Aug 21, 2012 | Hayward SAND FILTER, PRO SERIES
How do I change the sand in my hayward pro series 244t sand filter and how much sand do I put back in?
remove multiport shop vac sand out look at label on filter for sand quantity
May 12, 2012 | Hayward Pool & Spa
Sand from my sand filter is going into the pool. I have a S 244T
Inside the sand filter there are laterals that are PVC pipes with many narrow slots along their length. If a lateral is broken then sand will not be stopped by the lateral. Another possibility is that the part these laterals screw into is broken and sand leaks through. I hope this helps.
Aug 05, 2011 | Hayward SAND FILTER, PRO SERIES
I changed the sand and i can only vacuum about 2
Try consulting the owners manual for these pool filters. It will give you a lot of info in the settings that your filter needs to be on to do specific tasks. I really think that it will help you get this straightened out.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
NO SUCTION AFTER VACUUMING POOL
Did you use a trash plate? If not you have something stuck in the pipes and need to use an air compressor and blow from pump with main closed. Debris should shoot out!
Sep 25, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
239 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
