Question about Car Audio & Video
When i hook up my ipod to the kcu cable nothings happening and i cant even find an ipod source channel on the head unit itself
Is there an option for AUX or Auxilary input anywhere on the head? Try switching the input source through all possible settings while playing the ipod and ensuring the volume is on, to see if it plays.
Posted on Mar 13, 2011
Car Audio
Swap wires between speakers and to make sure it is not the amp, the head unit or wiring. If the right speaker still doesn't work touch a 9v battery to the speaker terminals for a second to verify if the speaker is good or bad (a pop the speaker is working nothing the speaker is bad)replace. Otherwise check the wiring between the amp and the head unit. If all the wiring is good you may have a bad channel in your amp(bad internal connection or bad component(s)) or last there could be a bad channel output on your head unit. If that is your only right speaker and you don't have one in the door and you use an ipod as a source check the cord!
Jul 04, 2013 | Car Audio & Video
Tried hooking up my tv to the satellite cable but I have nothing but blue screen and it says no signal. tried to auto scan and it wiped out all my channels. How do I fix this problem?
I think I see what happened here. Normally you have the tv cable connected to one connector and satellite or others to different connectors. When you want to switch you use your remote or the tv controls to change the source.This will preserve the scanned channels as well. On your remote you should see source or something like that. As you select it it should shows options like antenna, cable aux1 aux2 and so on.
So hook your tv up and rescan your channels. Then hook up the satellite to one of the other inputs. Then use the remote to switch the source. You will never see more than one sateliitel channel at a time and you will have to use the satellite remote to change channels on the satellite box.
Sep 25, 2011 | Westinghouse LTV-27w6 27 in. LCD HDTV
Cant find aux conection for ipod function pioneer car stereo deh-p6800mp just need help trying to get ipod playing
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer http://www.google.com/products/catalog?hl=en&source=hp&q=pioneer+ipod&um=1&ie=UTF-8&cid=9877805020289826524&ei=_vPKSpzyKYe4NrzrpPMH&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
Oct 06, 2009 | Pioneer DEH-P6800MP CD Player
CD changer output not working
There is an obscure setting for 'AUX' on/off that is hard to find unless you know what you're doing or looked in the manual. Typical Pioneer for ya.
Apr 19, 2009 | Pioneer DEH-P3600 CD Player
My Phase Linear UV8 and my Ipod
I wasn't able to find the manual for your Head unit. But, if you have jlink capability with your UV8 and you have an ipod jlink cable, you should just be able to plug the cable in. Then hook up your ipod and the head unit should recognize it when you try to select "ipod" for your source. I wish I could offer more info but like I said I wasn't able to see the manual and I am basing my answer off of what it takes for Kenwood headunits which use a similar "bus" type cable like your jlink. I hope I could help. Let me know if you need furthur assistance. I would happily help.
-Andrew Hawkins
Nov 24, 2008 | Phase Linear PCD120U CD Player
I have the pioneer DEH-P7000UB in a Vauxhall Vectra. I put the head unit in the car, connected my IPhone (not the 3G version) set the head unit to USB mode and it try's to read my IPhone then comes up with...
error 19 is a communication error code with the ipod itself so either the cable is bad or the connectiontion on the ipod or deck is bad or the ipod itself may have a bad rom for external use. this info comes straight from the tech support manual for Pioneer that we car audio techs use (even if you call pioneer they will tell you mthe same thing).
try this :
Disconnect the cable from iPod.
Once iPod main menu is displayed, connect the cable again.
Reset the iPod.
Oct 31, 2008 | Pioneer Car Audio & Video
Alpine 9884 and ipod hook up
No. This unit is designed to choose songs through the deck itself
Oct 10, 2008 | Alpine CDA-9884 Car CD/ MP3 Player
IPod and Sirius hook up
allpioneer products need power and ground to operate. check the fuse on the yellow wire. if ipod is not plugged in, it will not show as a source on the pioneer head unit
Oct 28, 2007 | Pioneer SIR-PNR2 SIRIUS Radio Receiver
Sirius Problem
The sirius unit does not have any channels in the unit.
You need to refresh the radio (XM allows you to do it online, I dont know about sirius) and leave it powered on for about an hour for it to update the channel list.
Mar 25, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
