Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Is there a saftey future on the back of tv if the back is off the tv wont come on
Why cant I open back door ?
Is the child Saftey latch enabled on. The door?
May 31, 2014 | 2003 Dodge Neon
Ford escpe 2008 wont start
place back in park or neutral. Cars now a days won't start in gear unless the neutral/park saftey switch is faulty.
Dec 16, 2013 | Cars & Trucks
Lighting ran in on my lg47lg50 tv now the red power light is on but the tv wont come on
The power board is cooked. consider another tv.. Consider using surge protection in future.
Apr 01, 2013 | Televison & Video
I have a 96 ford mustang Gt. When I push the clutch in the car wont start up. I have power and the battery and the fuses are good.
It should have a clutch saftey switch on the clutch pedal.Its a saftey feature simular to a neutral saftey switch it will only allow the engine to crank when the pedal is fully depressed.
Sep 07, 2010 | 1996 Ford Mustang
Viviteck 56''in.HDTV DLP TV. replaced with a new lamp bulb since I replaced this the tv wont come on only the sound for about 5 seconds then tv is silent again. any tips, Please.
The first thing to check on any TV that has a replaceable lamp is to make sure the lamp door is back on and seated correctly. You also need to make sure that the lamp is seated all the way in. The lamp door and in most cases the lamps have saftey switches they have to activate for the TV to work normal.
Nov 17, 2009 | Vivitek V37655 56" DLP TV
Power to toshiba tv, but it wont turn on
you more than likely have an intenal electrical problem.
usually tvs have a saftey feature to prevent further damage . you may have a loose wire or a connection that came un soldered inside. my suggestion is to take it to a reapir shop.
Apr 26, 2009 | Televison & Video
I have a kirby sentria and after I shampoo'd the carpets I put it back together to be a regular vacuum and now it wont turn on. Any ideas what could be wrong?
The only thing I can think of is the brush head is not on properly.If the head is not aligned right,then the saftey switch wont be activated.Otherwise,I'd say the saftey switch or power switch.Did you make sure not to run over the cord?
Dec 15, 2008 | Vacuums
Lcd tv
dos the porew light stay red or turn blue or not at all?
May 31, 2008 | Polaroid FLM-323B Television
My tv
may bethe capcitors get burned off . caheck ur main board with adeqaute saftey procedures
Dec 03, 2007 | Philips Magnavox 51MP392H Rear Projection...
Help
will i had the same problem yesterday.I got like a saftey pin and pressed the button in the back that says rest.Push the little button and it might work it worked for me and I hope it works the same way for you.
Nov 20, 2007 | Samsung YP-K5 MP3 Player
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
