Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxator 3200 - Is there a fuse (or something) - when power gone
Hi - I accidentially used the wrong power suply when using this drive - And lost power.
I hope I haven't damaged the disk.
I managed to open it up - and wondered which component i could replace (i.e which component on the board would act as a fuse) - There was no obvious fuse.
Any suggestions greatfully accepted.
Best Regards
Richard Pearce
    Champion:
  • 208 Answers
Get a new external case, take hdrive out of broken one.
Posted on Aug 01, 2008
Device driver download
STEP 1
Check the Power and Data Cable
  • Check that the power cable is securely connected to the external drive and wall socket (applies only to desktop external hard drives).
  • Do not connect the drive through a USB hub, connect it directly to the PC or laptop. Make sure the power adapter is connected directly to a wall outlet, not to an extension cord.
  • Ensure the cable is securely connected to both the drive and computer.
  • If your external hard drive came with with a Y-cable, use both USB connectors to ensure the drive is getting the appropriate power.
  • If you are connecting to a PC, use the USB ports found on the back of the computer. Avoid using USB ports found on keyboards, monitors or the front of the PC.
  • If the problem still continues, try using a different USB port.
STEP 2
Check the Drive Partition in Disk Management
Even though the drive may not be visible on the "Desktop" or in "My Computer," check to see if the drive is recognized in "Disk Management."
  1. Right click on "My Computer" and select "Manage" from the menu.
  2. From the "Computer Management" window select "Disk Management" from the menu on the left.
  3. In "Disk Management" check to see if the drive is visible. If the drive is found, look at the partition for the drive. New drives will be labeled as FAT32 and have a drive letter assigned.
  4. If the drive does not display as "Healthy," or shows the file format as "RAW," then the partition has become corrupt. It could also be corrupt if the bar above the drive is black and shows as "Unallocated."
  5. To make the drive usable again after a partition has become corrupt or lost start by right clicking on the drive in "Disk Management" and select "Delete partition" from the menu. Then right click on the drive again and select "create partition" from the menu. Follow the steps in the partition wizard to create a Primary partition.
    NOTE: Deleting the partition will cause all data on the drive to be lost. If the partition has become corrupt this may be unavoidable. HGST is not responsible for lost data. It is highly recommended that data be backed up in multiple locations on multiple drives to minimize data loss.
  6. After the new primary partition has been created "Disk Management" will display the drive with an NTFS partition. The NTFS partition is unusable on a Mac. If the drive is used on Macintosh and Windows computers, follow the link below to obtain a FAT32 formatting tool which will allow both Windows and Macintosh users to use the drive.
    http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm
STEP 3
Check the drive status in Device Manager :
  1. Right click on "My Computer" and select "Manage."
  2. From the "Computer Management" window select "Device Manager" from the list on the left.
  3. From the device list, expand the "Disk Drives" category by clicking on the [+] symbol found to the left. If the drive is detected by the system, there will be an entry for your external drive.
  4. If it is not listed under "Disk Drives," expand the "Other Devices" category and see if there is an entry for an "Unknown Device."
  5. Right click the "Unknown Device" and select "Properties."
  6. Under the "General" tab, it will typically display "This device is not working properly" followed by either Code 10 or Code 28.
  7. Code 10 would suggest a potential power supply issue (typically 3.5-inch desktop external drives). If a second external drive with an equivalent power supply is available, try connecting the power supply to the drive.
    NOTE: Before connecting a power adapter that did not ship with the external hard drive, verify that the power configuration matches exactly with the power adapter that was supplied. Failure to use the correct power supply can result in damage to the unit, injury or fire.
  8. If a different power supply is not available, verify the problem by connecting to a different USB port or by connecting to a second PC.
  9. If the same error code is still displayed, create an RMA and return the drive under Warranty.
  10. Code 28 would suggest a driver error.
  11. Expand the "Disk Drive" category in "Device Manager" right click on the drive and select "Uninstall."
  12. Disconnect the external drive, reboot the computer and reconnect the drive when the computer has finished restarting.
  13. If same error is displayed, try connecting it to a second PC to verify the issue.
  14. If the drive fails on the second PC with the same error, create an RMA and return the drive under Warranty.
Apr 06, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
Cant detect hdd
Hi Martin...
The problem is being caused by the Logical Disk Manager
Administrative service and possibly the logical Disk Manager service
not being started or the services might be disabled. to solve the
problem, click on the "Start" menu, click the "Run" command, and then type
in the box: services.msc , scroll down until you see both the above services.
right click on each of the services about and select properties, on the
general tab, change the startup type to "automatic" and click the start
button under the service status. do this for both of the services, and
that should will fix your problem."
For Windows 2000 and XP:
Right click on My Computer.
Choose Manage (This will open the Computer Management window).
Go to the Storage category and select Disk Management
Right click the new drive (usually listed as Hard Disk 1) and "initialize"
You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended for most users.
External hard drive can not be recognized, are more common on computer
failures, what's the reason caused this failure?
1, Setting the CMOS parameters
If you never used the USB external device, there may occur the case:
The system can not detect USB hard drive even if the driver is properly
installed, which was mainly due to the motherboard CMOS default port is closed, if not set to
open state, it naturally Windows can not detect the external hard drive. In order to solve this
problem, we can re-boot into the CMOS settings, and set "Assign IRQ For USB" to "Enable" in
"PNP / PCI CONFIGURATION" column, now the system can be assigned to the USB port available
interrupt address.
2, Power shortage
As the USB drive need to consume some power when it at work, if directly through the USB interface
to take power, the power supply may be not enough. Thus, almost all of the external hard drive
comes with a separate external power supply or a PS2 keyboard to take power transfer interface,
at this time you should connect external power supply or through the transfer cable ps2 connected
to keyboard to ensure that it have provided adequate power to the external hard disk,
recommended that you should ensure the external hard drive have adequate power supply when you
use it, otherwise, the external hard disk is likely to be damaged due to insufficient power
supply.
3, USB extension cable fault
USB interface type does not match the external hard disk interface ,this case caused it can not
be used. For example the standard USB interface of the computer configuration is 1.1, while the
external hard drives purchased are USB 2.0, which requires the cable connected computers and
external hard disk must support USB 2.0 standard. Because high-speed mobile device plug in a
low-speed hub, the device may not be properly installed, and some people use external hard disk
while using USB flash drives, For convenience, they directly used USB 1.1 standard cable that
supplied by USB flash drives, as a result, the USB 2.0 standard hard drive not be recognized
correctly. Just replace it by the USB 2.0 standard cable can solve this problem.
4, Windows version is too low
Pre-Windows 98 operating system does not support USB peripherals, so in any case to install the
driver, set the CMOS parameters are unable to make normal use of external hard disk. In this
case, one solution is to upgrade the operating system up to Windows 98, another way is to
Microsoft's official site, download the appropriate patch to make it can identify mobile hard
disk.
5, The system is set incorrectly
When installed driver, the external hard disk icon will be seen on the Device Manager for some
Windows 98 users, but the Explorer does not include the corresponding letter identification,
which is improper system settings. In the Device Manager, double-click the Hard Drive icon, and
click the pop-up window in the "Properties" button, and you could see disconnect, could be
deleted, synchronous data transmission and Int 13 unit four options, of which "could be deleted "
is no tick in front of the system, and simply check this option to restart your computer, you can
see in the Explorer, the new external hard disk drive letter.
While the failure of the external hard disk does not recognized are more the reasons, but
generally not the USB interface or external hard disk's own fault, so it requiring us to consider
some more from around the association when exclude it, I believe you can successfully use the
external hard disk.
Hi I had the same problem and solved it like this assuming that you are running windows xp
With your external casing powered-up (it does not get power through USB does it?) and your WinXP
PC running, plug in the USB.
You should hear 'chime', what happens then?
If harddisk is recognised here, but does NOT have a drive-letter and cannot be seen in Windows
Explorer, the answer is in Windows Disk Management
Go Administrative Tools > Computer Management > Disk Management. ( on left column)
Maximize this page. Physical Drives appear at the bottom; Logical Drives at the top.
Hopefully your drive will appear at the bottom (physically), you must then 'import' it into the
Windows installation
; Windows will put its 'signature' on the drive and assign it a logical drive letter :^)
you can try to format it here if it is new and has no info on it , check back to My computer and see if present.
Mar 20, 2013 | IBM FRU PN 49P1599 Desktop Motherboard
32GB microSD card Damaged
Click start control panel Administrative tools Computer Management Disk Management right click on your drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive. You might get best results ticking in one box the returning after it has finished then ticking the other box it might take some time depending on the of your disk but be patient. Hope it helps.
Jan 11, 2013 | Electronics - Others
I can not initiliaze wd 160 Gb disk! I just delete all from disk and whan put in USB, power Ok but no name in my computer?
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery software to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | Western Digital Passport 320GB External...
My eclipse 180 mp3 player is not being recognized by my computer
Hi wfowler05...
This is for an external hard drive, but the same applies to your MP3 player
interrupt address.
2, Power shortage
supply.
disk.
external hard disk.
Please take time to rate me
Aug 30, 2011 | Mach Speed Eclipse 180 MP3 Player
Lost NTFS partition on my WD1600BEVT, how do you restore so I can use again?
Depends on what you did to "lose" the partition-table.
Download the free 'PTEDIT.ZIP' file -- it is a "partition-table editor".
UNZIP it on a different computer, and extract the 'PTEDIT.EXE' program.
Run PTEDIT on your computer, and update the partition-table.
Jul 14, 2011 | Western Digital WD1600BEVT 160 GB SATA II...
How can i able to use my usb flash drive, it won't open due to i haven't remove it while my computer is formatting.
Hi arjeevergel ,
The USB drive should work fine even if you have removed it while formatting your hard disk (if this is what you mean when you say formatting computer).
Try connecting the drive to some other slot after you install the operating system and check it it works.
If it does not work , then you can probably check it in your neighbor's PC whether it's been detected or not , if it's being detected then the problem could be that your USB ports have been disabled which you need to enable via BIOS or the hardware manager.
Hope this helps ...:)
May 10, 2011 | Electronics - Others
Not showing on pc
If it does not show up on 'My Computer', verify they are getting power and check for issues in Disk Managment in the 'Computer management' console(search for computer or run compmgmt.msc).
The Hard drive may need to be initialized or formatted.
If you do not see the hard drive in the computer management console/Disk managment, there could be something wrong with the hard drive(bad connection or no power) or something wrong with your computer. Verify by checking the hard drive on another computer.
Mar 18, 2011 | Computers & Internet
Hard Disk Problem
first download and install Drive Rescue . Click on Find lost drive, select the drive you miss and click "find logical drives". Now you should access all of your files. Save them to another drive and format the hard disk.
hope to be helpful
Riccardo
Aug 03, 2008 | Computers & Internet
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Jan 06, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
82 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
