Question about Whirlpool Washing Machines
Whirlpool washer leaking from underneath from white discharge and motor area. Is there a teflo
  • 2 more comments
  • brooksdhobso Mar 13, 2011
    Is there anyway of repairin the one I have
    Can I use one off an older washer
  • brooksdhobso Mar 14, 2011
    So what's that mean that I need the motor to
    Would it be better to just get a new washer
  • 351 Answers
It would mean that the water pump is bad. I have them in stock but i need the model number i can ship them out to you tomarrow.
Posted on Mar 13, 2011
  • 1 more comment
  • Mark Nichols Mar 13, 2011
    No there is not it is plastic. They go bad where the shaft of the motor goes into.
    If the part numbers match up yes. Good luck trying to get it off though and even yours they stick.
  • Mark Nichols Mar 14, 2011
    No you will have to almost beat it off the motor(carefully) and if you do that then it ruins the pump so most of the time it doesnt even pay to get a used pump because 1. if it sticks and you get it off the chances of that one working is very slim.
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Water leaking on floor? How to fix
Depending on how old the unit is will depend on where to look for the leak. You have an incoming water line, a motor (with an impeller) and a discharge hose. First look at the hoses, motor assembly and areas under the washer tub for tell tale signs of leaking. Look for staining, usually a line like white powder will lead you to the leak. If none is found, start with the incoming line; first look at the valve that feeds the dishwasher, see if that is leaking. if it is, it will have to be replaced. Look at the feed hose to the dishwasher and see if it is brittle and cracked, if it is, replace it.Look at the discharge hose for brittleness and cracking as well, also check the connections to insure they are tight. If the hoses are found to be in good shape then look at the motor. There is a gasket that is in between the motor housing and the washer, see if it is leaking if so, replace it. You will have to remove the dishwasher to access the motor so be prepared to spend some time to complete this. Good luck and I hope it is just a hose issue.
Oct 20, 2014 | KitchenAid Dishwashers
Washer leaks
There is also a discharge lint filter on the front lower left that has to seal properly. If the water appears only when washing, you can probably eliminate leaking from the water supply side up to the solenoids controlling the water. The most likely source is a leak in the rubber section between the tub and the front door, a leak in the seal between the door and the washer, a leak or overflow in the soap dispenser, or a leak in the discharge side components. You could probably figure out the source if you could view these areas during a cycle, but that would require some disassembly of the cabinet so that you would need to know what you were doing.
Jul 13, 2014 | LG WM2101H Front Load Washer
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
Apr 19, 2017 | Kenmore 24732 Top Load Washer
Leaking water from underneath
The door connects to a round gasket called the "bellows". If it is torn, deformed or coming off water will leak underneath. Undo the 3 screws in the lower front panel and do an inspection of that area
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaks when filling
It could be a swollen impeller inside the pump causing it to wear a hole in the plastic housing and making the humming noise .It,s fairley easy to replace as it clips on to the end of the motor.Hope this helps.
Nov 28, 2009 | Whirlpool LSR5132PQ Top Load Washer
Leaking underneath
Maybe its not draining completely? Have you tried opening the front panel, pulling out the white plug, putting a bucket under it, unscrewing the front of the plug and checking the filter?
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak from my washer underneath i have a Whirlpool Duet Sport® HT 3.7 I.E.C. cu
Check the filter, as it may be leaking. To do so, take white panel off the front, put a bucket in front of the unit, unseat the rubber feet holding in the white plug and pull the white plug out, unscrew it, allowing water to run into the bucket, clean filter, check the gasket, as it may need replacement (if so, replace it), then screw white plug back in, push plug back into unit, secure the rubber feet, and replace the front panel.
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
