I have a kyocera FS-1100 printer. The paper light is flashing but I have the correct size paper in the paper tray and the paper tray is inserted correctly - any ideas as to why it is flashing
  • 591 Answers
Is the paper size correct in your OS (Operating System) printer configuration menu??? (Windows/Linux)... check for a paper JAM in the printer... what are you trying to print??? (pdf, jpg, doc, xls, etc...) if you do a PRINT TEST from the OS PRINT MANAGER does it work???, if you do a DEMO TEST PAGE from the printer does it work??? I need more information to help, it could be a bad DRIVER, bad CONFIGURATION, a BAD SENSOR in the printer it self, have you power cycle (turn OFF than ON) the printer???
Hope this helps!
Posted on Mar 13, 2011
How do i check the paper sensor on a kyocera fs-1100? where is it located?
Usually in Kyocera located in the middle upper when you pull out the tray.
Nov 19, 2014 | Kyocera Mita FS-1100 Laser Printer -...
Paper jam in tray one after receiving every photocopy in kyocera fs6525 wht's a problem ???
First make sure that tray is set up for correct paper size. That would be first thing. Check for paper dust in paper path blow it out. Really sounds like paper tray not set correctly.
Feb 23, 2014 | Kyocera Fs-6525mfp Copier, Printer,...
Kyocera FS-920 RED LIGGHT IS BLINKING AND GREEN LIGHT IS OFF
There are 2 possibility to cause your printer acting like this:
1) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
2) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
If it is condition 1) then just remove the jam paper then open and close the Top Cover to clear the error.
If it is condition 2) then insert some paper in the paper tray.
YBC (/\)
Jun 05, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera fs-3900DN
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
KYOCERA FS-1030D - 3rd Light from top is Red
this is problem with cassate please add paper in cassate.
* in cassate at last one green color botton is there set that one as per paer size
* after remove the cassate see at front left down there one white color sensor is there this sensor senseing the cassate availbilty please check that one
* while inserting cassate insert slowly
Jul 06, 2008 | Kyocera Mita FS-1030D Laser Printer
The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
183 people viewed this question
k24674
jasbo
jasbo
