Question about HP LaserJet P2015dn Printer
How do i remove left side cover from hp p2015 printer to remove formatter board
  • HP Master
  • 1,915 Answers
To open the side you need to remove the paper tray and open the front door. This side of the printer comes off from front to back. Place a flat blade screwdriver under the front of the left panel and pry forward till it clears the tap. Do the same for the bottom front. The side can then be pulled away and pulled towards the back where the other two tabs are. When replacing, just reverse this, put the panel over the back tabs first and press the panel in. At the front, use a screwdriver to gently lift the panel over the front tabs.
Posted on Mar 14, 2011
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
Jan 29, 2014 | HP LaserJet P2015 Printer
It just quit communicating with pc
First off, try uninstalling your printer and reinstalling the cd you have. If you don't have the CD then download the drivers from the support and downloads tab on the HP website. If that doesnt work then on the left side behind the panel is a formatter board and on this particular model these have a bad tendency to go out.
Jan 23, 2011 | HP LaserJet P2015 Printer
HP design jet 800 series poster printer showing error message 05:10 Then after I hit next, it shows serious error 0x4050002. Appreciate you help in fixing this problem.
That error means the formatter is either loose or defective.
Try removing the LAN card cover from the back left side of unit then loosen the 2 screws, remove the formatter and reinstall it. If that does not solve the problem. You will need a replacement board.
Oct 28, 2010 | HP Office Equipment & Supplies
Printer keeps going in sleep moew, have to power on and off for it to prnt.
Mostly it is caused by a defective formatter board, partnumber Q7805-69003. After replacing the formatter board all should be OK.
Gerrit Jan
Nov 05, 2009 | HP LaserJet P2015 Printer
Complete Shut Down
These HP's are notorious for Formatter (main board) problems. probably not worth fixing.
Aug 17, 2009 | HP LaserJet P2015 Printer
How do I replace a formatter board on an HP 3005N. It is out of warranty and I don't want to take it to a retailer to fix. Thanks
Hi there Fairly simple process romve the right hand side cover (slide to the back of the printer and lift off) open the formatter board protection cover hindged at the back then disconnect all cables and remove the formatter board Regards AL "alstech"
Jun 15, 2009 | HP LaserJet P3005n Printer
HP p2015 printer has stopped printing
check inside the toner door on the right side. there should be a plastic tab which opens the laser shutter when the door is closed. if this is broken then the lase shutter will not open and will produce blank pages.
Jan 15, 2009 | HP LaserJet P2015 Printer
LJ 2015
pull off the left side cover from the rear and the formatter is there order one from hp partsurfer.com
Jan 08, 2009 | HP LaserJet P2015dn Printer
HP P2015 Has Paper LED Solid Lit. Will not go off. Help!
It seems that none of the printer's sensor is faulty, in fact, the printer has a faulty firmware on the formatter.
Your printer may need replacement of the formatter board, however, please try the following before swapping the formatter.
HP LaserJet P2015 Printer Series - Paper Jam Light Solid ISSUE: The HP LaserJet P2015 may come up with Paper Jam Light solid and would show the same light pattern even if the printer is power cycled.
SOLUTION: The Light pattern is as shown in the diagram below.
Perform the following tasks in the order listed.
1. Reset the printer using the Super NVRAM initialization. The procedure is
a. Turn off the printer
b. Press and hold the GO button
c. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process the Attention, Ready and Go light turns on. Then the Attention and Ready light turns off, leaving just the Go light illuminated.
d. Release the Go button. The Go, Attention and Ready lights turn on.
e. Press and hold the Go button. All lights turn off. During the next three seconds, the Go, Ready and Attention lights turn on in that order, one per second.
f. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
2.Unplug the power cord when the printer is on and leave it unplugged for 10 Seconds.
3. Turn the printer back on.
If the above steps resolve the issue, then print a configuration page and check the firmware version and the formatter board no.,
If the firmware version is below: 20080312, then your printer needs to upgrade the firmware, however the firmware can be upgraded only onl those models whole formatter board's third number from left is 0, 1 or 2, eg: JK0xxxx
If the 3rd number from left of the formatter board no is anything other than 0, 1, 2, then firmware cannot be flashed.
Please let me know the next update.
- Nikhil
Nov 08, 2008 | HP LaserJet P2015dn Printer
Stopped printing
Sounds like you need a new formatter board, you could verify this by swapping it with the good printer
May 15, 2008 | HP LaserJet P2015 Printer
HP LaserJet P2015dn Printer Logo
1,094 people viewed this question
Seeker5211
Seeker5211
