Compressor model # zr28k3-pfz-130 unit #h2h332aka100or h2h338aka108 i believe it is this one hard to read bought it from a man who said 5 ton but ut has 3/4in. lines coming out of compressor so i do not belive what he said can you tell me how to tell what size it is
    Guru:
  • 683 Answers
What is the name on the compressor.
Posted on Mar 13, 2011
  • Walter Kunesky
    Walter Kunesky Mar 13, 2011
    I hate to be the one to tell you this but it is a 2.5 ton. You see the 28 in the model number, 12,000 btu per ton of cooling, the 28 makes it 2.5 tons.
919165130 Craftsman Compressor - how to wire for 220V
Check all wring. Remove cove and see if you can turn over by hand.If you can't unit is broken/frozen.it should run on 120. look at the plug if prongs are vertical the unit 120vac. Look on motor wire box if it can be rewired it will be there. I doubt this unit is designed to operate on 120vax. The mots/pump assembly is not available for purchase. there are a few repair parts available. do you want to spend the time and money for rewind.? good luck
Feb 21, 2018 | Craftsman Air Tools & Compressors
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
My Makita air compressor will not adjust to a lower pressure. I am putting cedar shakes on the house and I dont want the nails to push so hard in the shakes. When I adjust the nob in the minus (-)...
It sounds to me like your regulator is shot. It is the knob you have been turning in the (-) direction. The gauge reading 120 is the regulated pressure and the gauge reading 130 should be the tank pressure. You can find a new regulator from any Ace Hardware store.
Aug 03, 2011 | Makita MAC700 2 HP Air Compressor "The Hot...
GE Model AZ25E09D3CM1 Serial HF 655868 No unit reponse at all regarding fan operation or compressor. Unit seems like no power supply. There is 240 vac power, 24vac supplying the outer board &...
Not certain but I believe 19 is required. Where are you reading this 16.9 and take a reading from the outdoor unit WITH OUT the wire attached and see what you get. Possibly a bad wire heading inside or weak transformer.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 29, 2018 | GE Zoneline AZ35H12D Air Conditioner
My compressor gauge does not go below 50psi and when i turn it on the gauge goes up to 180 psi
This sounds like the gage is out of calibration. 50 psi sounds about right for this model. I believe 120 psi is max press. and it should pop the safety at 130 psi. Drain the tank, it has a drain at the bottom of the tank. Remove the gage from the fitting. It should read 0 with it out of the system. If it does not read 0 she is out of calibration. I do not believe this gage can be calibrated back to 0 if it is sprung. You will have to find a new one or do the math in your head. If the gage does go back to 0 once removed. Your regulator is bad, you can try to rap it with a hammer handle to see if that will get it back in line. Next step would be to replace the regulator assy. Hope This Helps Fix Ya up.
May 16, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a custom built Randell refrigerated sandwich prep table. The compressor is making a strange noise (rattles) and the temperature is too high (50 deg). The sticker on the motor reads: Model ...
If you were told to replace the entire compressor unit (condensing unit), the person diagnosed the compressor is most likely bad. Depending on the age of the unit, it is hard to tell if this is a good decision. Overall condition plays a role in the decision process as well.
Jan 18, 2018 | Randell Refrigerators
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Need to replace the alternator on my 1998 aurora w/ 4.0 northstar engine. any exploded view diagrams or diagrams period available?
Hey man, it's not too bad. Discharge the A/C. Take out compressor, take out bracket, take out alternator. There will be 2 bolts on the top of the alternator which are kinda hard to get to. Then there are two bolts on the in side of the compressor and I believe 4 total on the front. Google an electric motor repair place in your area!!! I get mine rebuilt for $50 vs $300 form a parts store. Or, get a brush kit. I believe on those you don't even have to take the alternator apart, only the black cover on the back. There you go, $12 you did it yourself.
Nov 05, 2009 | 2001 Cadillac DeVille
Goodman unit freezing outside the unit
Its not the thermostat.
The things that can cause this problem are lack of or poor airflow over the Evaporator coil. Or a low system charge. Or quite possibly a restriction in the line on the low side. When they replaced the compressor did they purge the line set with nitrogen and pull a deep vaccum? This is imperative when replacing a condensing unit to ensure that no residual particles are left in the line set to create a restriction.
Hope this helps You
please rate me
Jul 24, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
