Question about GE 31GT740 31" TV
I have a GE 31GT740 31" TV That turns itself off and then back on every few seconds. There is now a broken (dashed) white line that goes from the very top center of the screen to the right side. The TV will stay on until a comercial comes on and then begin shutting off and back on several times. On cable channels that have no comercials, it will stay on for an entire movie and then begin again when the comercials start. When playing a DVD it will cut on and off at the beginning, when previews, etc. are playing sometimes say "unusable signal" then play the DVD fine. Any suggestions?
  • GE Master
  • 1,210 Answers
I would be concerned with the vertical IC. This IC has pins that have separated from the board itself. You will note the area under the vertical IC is almost black. It will do no good to resolder this. You will need to replace the vertical IC with a new one. And be sure to replace those electrolytic capacitors near and next to the vertical IC. Bad grounds on the this IC will cause your TV to shut down. Also inspect the rest of the TV board. In some cases the retrace cap will always need resoldered! But please inspect all areas of this board for bad grounds and resolder as necessary! Good solid grounds will give you a dependable set. Thanks for asking and show a few hands of support!
Posted on Mar 14, 2011
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
My sharp LCD tv won't turn on,it goes off after a few seconds.
Time for a new TV. or you might unplug it let it set for a while and then plug it back in see if it reset itself.
Mar 13, 2013 | Televison & Video
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
My television suddenly turned itself off while switching from video to hdmi. Now it will only turn on for a few seconds and shows a "no signal" message, then shuts itself off.
We have a 42" Model XV42L HDTV10A 100-240V,2.5A,50/60HZ....when we turn the TV on the screen is flickering and then shuts itself off....sometimes it will come on for a few seconds and then shuts off
Dec 16, 2010 | Vizio 42 in. LCD TV
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
It Quit!
call or contact samsung
Jul 04, 2008 | Samsung DLP HL-P5663W 56" TV
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
GE 31GT740 31" TV Logo
147 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
