HI THERE, I'VE JUST BOUGHT A Korg m1 , when i turn it on and try to use the pitch-bend it doesn't work (the korg m1 looks very new it's been used for few times ...) now i don't know if the pitch bend is brooken or needs only to set-up. PLEASE HELP ME WITH THIS . THANK YOU VERY MUCH.
  • farichrachid Mar 14, 2011
    HI,
    THE FIRST I TURNED ON MY "KORG M1" THE MESSAGE ON THE DISPLAY WAS : -low battery int-
    ALTHOUGH THIS MESSAGE THE KORG M1 WAS WORKING ,BUT
    THE JOYSTICK NO.
    DO YOU THINK IT WILL WORK(THE JOYSTICK) AFTER REPLACING THE OLD BATTERY BY A NEW ONE ?
    (MY KORG M1 IS A SECOND HAND BUT BEEN USED FOR A COUPLE OF TIMES , INFACT IT LOOKS REALLY NEW.)
  • farichrachid Mar 17, 2011
    THANK YOU SOOO MUCH, THAT WAS THE SOLUTION ;
    ONCE I RESET THE FACTORY SETTINGS ,THE PITCH-BEND
    STARTED WORKING, IT'S JUST WONDERFUL .
    THANK YOU AGAIN.
    RACHID.
  • 5,603 Answers
The pitch bend should work. I have the rack version which is MIDI driven, but the M1 has a similar joystick to the W1 I have. I believe you can select whether the pitch bend and/or modulation can be applied to a particular voice. You need to dig through the manual to find how to do that. The mechanical mechanism and pots on the joystick are fairly durable and there are two functions. If neither work, I suspect the pitch bend is turned off for that voice. I would first search for the FACTORY RESET procedure and do that.
Another thing is to drive the M1 via MIDI from another keyboard with pitch bend to test the function... ALSO go the other way and see if the M1 can pitch bend another keyboard that is capable of pitch bend.
Posted on Mar 15, 2011
  • Fred Yearian Mar 17, 2011
    Good to hear it is working. If it fails again, have the backup battery replaced. Settings are usually contained there and once a new battery is in place, do a factory reset again. The batterry in M1's due to age are probably getting near end of life.
    Brigadier General:
  • 3,513 Answers
Hi
Please check this link in detail if it helps you:-
http://tlittle72.tripod.com/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 14, 2011
The pitch bend of my Korg pa500 Ort just stopped operating properly yesterday, the problem is that "up & down" is functioning normally but "left & right" is not working (no...
The first thing is to verify that it is supposed to work with a particular performance. NOT ALL voices support modulation as well as pitch bend and with an arranger you can turn this feature on and off, usually in the utility functions and then save the setting for each performance/song. Read you user manual about modulation. On page 271 of your manual they show that the joystick is assignable. You have to assign the functions to the effect you want.
Jul 30, 2011 | Korg PA500 61KEy PROFESSIONAL ARRANGER...
My internal battery is depleted. how do i change
Do you meant Korg M1 ?
How to replace Korg M1 internal battery, read HERE
FixYa can only give you the guide requested but for DIY, you are responsible for your own repairs.
Jul 24, 2010 | Korg TR76 76 Key Synthesizer Workstation
TR76 76 Key Synthesizer Workstation : i own a korg m1 however by accident my dad knocked...
Most likely an electronic item could have broken in the circuit board, a resistor, transistor, capacitor, etc. Take it to a technician at a repair shop. Have them take a look at it, usually estimates are free.
May 06, 2010 | Korg TR76 76 Key Synthesizer Workstation
When I play the sound come out distorted, like it untunes. any idea what is causing the problem? this is a for a Korg X50 and is only 2 yrs old. not korg Ma30
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Aug 19, 2009 | Korg Ma30
I dont know how to replace the internal battery on a Korg M1
You should be able to remove the top cover off your keyboard and see the quarter-size battery mounted in a holder on one of the circuit boards.
I don't recall the exact location on this particular model, but once you've located it, all you have to do is slide it out from under the contact spring that holds it in place and slide a new one in.
You'll want to make the swap fairly quickly as some models can lose their memory settings if battery power is lost for a relatively short amount of time.
May 20, 2009 | Korg Pa800 Synthesizer
Problem with Korg PA-50
Try to download the Operating System from http://www.korgpa.com/pa_root/en/products/pa50.html?en
Jan 14, 2009 | Korg Legacy Collection
Korg X2 Floppy Drive Fix/Replacement
Hi, here it is the best solution. FlexiDrive for Korg X2
It is working fine with Korg X2.
http://www.floppyemulator.com/products/flexidrivemv-usb/
info@floppyemulator.com
Cheers!
Jun 05, 2008 | Computers & Internet
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
