Question about Sony Playstation 3 (PS3) Console
My unit will not boot up with picture, I only get sound. Is there a way to reset the unit other than removing power completly.
  • 3 Answers
Make Sure AV Cables (Yellow,Red And White Cables) and HDMI Cable is connected
Posted on Mar 13, 2011
Why my desk top computer no sound no picture complete dead
Make sure you are getting power to the receptacle, a circuit breaker may have popped. If you have a surge protector then push the reset button. If you have power to the receptacle, then insert windows cd in tray before turning it on, then select boot from cd then hit enter. This will often recover the boot sequence and load the desktop screen. Restart the computer without the cd and see if the desktop comes up. Good luck, had to do this to a desktop unit running Windows XP.
Jun 02, 2014 | Sony Playstation 3 (PS3) Console
My apple 13" laptop not
I would try a SMC reset first, if that doesn't work for you, a PRAM reset might as well.
To perform a SMC reset, remove the battery from the unit, and remove th e mag safe adapter. now when there is no power going to the unit, press and hold the power button for 10 seconds. replace battery, and power and try to start the unit.
To perform a PRAM reset, turn the unit on, as soon as it turns on (before the apple logo pops up) press and hold "CMD" + "Opt"+ "P" + "R". Continue to hold until you hear the unit "chime" 3 to 4 times. then let go and see if it boots up.
Now if these help, then great, your in business, but if you leave it for a while on, and all you see is a folder with a "?", then you most likely have a dead Hard Drive.
Jan 25, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
I have just purchased a Belkin Basic Wireless Modem Router. I tried installing it but when doing so it tells me to check that the cables are connected. I have done this but it still won't install. Is...
After you have installed the unit shut everything down. By shut it down I mean remove all power. This includes the computer. leave all power removed from unit(s) 1 minute. When powering back up power up cable modem first if you have one. Wait for unit to completely boot up. Next power up the wireles router. Once again wait for it to boot completely. Lastly boot your computer. Hope this helps.
Dec 23, 2010 | Belkin Basic Wireless Router
My computer wont boot up. It says Boot failure. I ran a diagnostic test and it said i had a "biohd-3" error? What is that and how do i fix it?
Hi
Just reset you bios and see. I will tell you simple way toreset system for your BIOS
1. On the motherboard there is a small watch battery. Remove this battery alongwith the power cable from the power supply. Hold down the power button to fullydischarge the system. Wait 2-3 minutes then reinstall the battery and plug inyour system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Let's say that thejumper connect with pins 2 and 3. follow picture with this link http://www.computerhope.com/issues/ch000235.htm b> Remove the jumperwhile the machine is OFF and place onto pins 1 and 2. Now Power on your machinefor a minute. (Note: Your system willnot POST). Shutdown your machine and put the jumper back to pins 2 and 3. Nowyour system will POST. Your reset is now complete. Now you switch off the pc and fit the sata /pata cabletightly. If the problem same please fitthe cable as NEW.If the problem is creating same please install a new DVD/CD RW. Hopeit solve you
Dec 03, 2010 | Computers & Internet
My Palm tungsten E2 hand held PDA is totally frozen and locked up
Best thing to do here is to remove any memory cards etc.. and do a hard reset - seems like soft reset will or has not worked...
Press and hold the power button - keep it pressed and gently press the reset button on the back of the handheld.
Wait for the Palm Powered logo to appear and release the power button.
You should get a message warning about erasing all data. Press up on your 5-way navigator to reset.
This will erase all data inlcuding user information from the device, but synchronizing should get it all back - but you will loose anything that was not recently sync'd
good luck
May 27, 2009 | Palm Tungsten E2 Handheld
Screen is stuck
Did you try to remove the chip yet?, sometimes that helps, and re boots the system?
Failing that, try to remove the battery, to enable the unit to completely power-down. Then refit, and try again.
There is a reset function, but i am assuming you are unable to access that if the screen is frozen.
I have listed how to remove the battery on another post on here.
Good Luck
Jan 30, 2009 | Navman iCN 330 GPS Receiver
Dell Inspiron 6000 Laptop Won't Boot Up
The laptop won’t POST after removing the memory? Sounds like the memory module (s) need to be reseated again. Removing memory will not reset the laptop. If you want to install a clean Windows XP load, you need to boot from the Windows CD and format the hard drive.
Fell free to contact me if you need futher assistance.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell INSPIRON 6000 CENTRINO...
The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Soft Reset erases everything
Hi, i remember reading somwhere that if you hold the soft reset button too long you will deactivate the battery. You can reactivate it by inserting the PDA into the cradle. Hope this helps.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
Sony Playstation 3 (PS3) Console Logo
12 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
