Question about NEC MultiSync VT580 Multimedia Projector
I turn the projector on and it powers up but the status light blink......it does blink more than six times so it is not about the lamp
  • 40 Answers
Have you cleaned AND RESET the filter timer?
Posted on Mar 13, 2011
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
171 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
