I need a manual for the DIMPLEX PW4 Hot water Thermastat
I need a maunaual for a dimplex pw4 hot wate r and heating dsystem plz can someone help me. xx
Posted on Sep 04, 2012
Need the manual for dimplex air heater modle #6901470100
You can contact Dimplex directly, and have them email you a copy of your manual:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 14, 2013 | Dimplex Heating & Cooling
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
I have a mazda 626 td which I have fitted a new radiator to. Top hose is very hot and bottom hose is cold.When I undo the bleeding nut on the radiator and rev the car a little air bubbles come out, which I...
You may have a circulation problem, check this with a COLD engine, trun heater temp to cold, drain coolant, remove both hoses from the radiator, take a garden hose and put it in one of them, turn the water on, it should freely flow out the other, you may need to wrap a towel around the hose to get a bit of a seal, but it should not take much pressure to get it to flow, no flow? Are you sure the thermostat is out? Good flow? try the same to the radiator, does it flow? If both flow you may have an impeller that has come off your water pump, to test, reconnect bottom hose, leave top hose loosely connected, fill with water, start it, slowly pull the hose back, water should be flowing out with a good flow, if it isn't, you either didn't find the t-stat, or your water pump is kaput. Seems the t-stat is in an odd place on some of these, do you have a manual? look again because it sounds like a broken thermostat that is not opening, especially if your water flow test failed - no flow. Hope this helps
Apr 27, 2010 | Mazda 626 Cars & Trucks
Dimplex Electric Heater Model Number DF 3003 fan motor not working. How do I access the fan motor to repair or replace it?
Dimplex has a Service Manual for your Heater. I recommend requesting the manual through their Literature Request website. I located the owner's manual and the troubleshooting guide via their website, but it appears you will need to request the Service Manual.
Hope this helps.
Mar 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Replaced radiater ,thermastat still no heat and
Did you run engine from cold, WITH HEATER ON, and fill cap off when re-filling system? If not, try that and see what happens. Let the engine get up to operating temperature and rad fan come on to cool 2 or 3 times before putting cap back on.
Nov 17, 2009 | 1995 Subaru Legacy
My servis automatic is not letting in hot water on any wash..is this a thermastat problem..and how much roughly to repair?
sounds like the hot water valve. repair would cost about £57 if this. check to see there is hot water getting to the machine first.
Jul 31, 2009 | Washing Machines
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
Water leak with the dimplex dac12ac
Hi there seems to be a water outlet at thtop rear of the unit where you need to drain water from its a little" rubber plug" hope this helps good luck
Dec 07, 2008 | Heating & Cooling
Overheating
Posible thermastat sticking closed. If thermastat doesn't open heated water is trapped in the engine causing it to run hot and not allowing hot water to travle to the heater core when called for.
Nov 20, 2008 | 2002 Mini Cooper
Water spillage in Dimplex portable air conditioner
Hi Leanne,Bung stays in and you dont take it out until the red light (4th on right on top of unit) comes on, then you empty it taking bung out and use tube to get the water out. It will probably take some time (days of continuous operation) for the light to come on, depending on your humidity etc. For easy emptying, wheel the unit to a bathroom or outside where if it spills a bit it won't matter.
Ours is working okay although it just stopped blowing cold air and is only blowing room temp air. we have guests tonight and its hot! I came here looking for a solution to my prob and found yours!
chhers, Les.
Jan 01, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
388 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
