Question about Video Cameras
I have a camcorder JVC GR-DX67EK which worked fine and suddenly as I started it up the message "Lenz Cap" came up (as it normally does). But this time, it didn't clear up as I removed the Lenz Cap. Now - with lenz cap off, I can't see anything on screen or viewer. Everything else seems to be OK, including playback: when I play the cassette, I can seen the film ok. Can you please help! AB
  • 40 Answers
Look for a switch somewhere around the lens that is probably stuch triggering the OSD to display "Lens Cap". You may have to depress nthe switch with a toothpick or paperclip. Look at the lens cap for something sticking out of it. That would be the actuator. Line that up and you should then find the switch.
Posted on Mar 13, 2011
  • sonsalab Mar 14, 2011
    Hi Bob Smart,
    Thanks very much for your response. The problem with my JVC GR-DX67EK persists. Can't see any switch about the lenz at all. But I must add that the message "Lenz Cap" only flashes 5 times and disappears, with or without Lenz Cap.
    Also, I have noticed that someone else on this forum has the same proble on his JVC GR-D20EK Camcorder, which he expressed as follows: " Lens Cap warning on Problem with the JVC GR-D20EK Camcorder. Lens Cap warning on display even with the lens cap off the lcd screen is black. will playback but not record".
I am having JVC d50 mini dv camcorder. i am getting message as "please wait, condesation' I switched it on for several hours and switched it on still this message is there. During message the...
your dv cam sensed a condensation means some moist is inside the unit, to protect the sensitive electronics on it. it disabled normal function of the dv cam. try to avoid placing the dv cam from sudden cold area to hot area, or vice-versa do not use dv cam until condensation message is gone
Feb 15, 2011 | JVC GR-D50 Mini DV Digital Camcorder
Camera worked great until last month!
OK, it is known problem of CCD Imager chip failure in JVC GR-D33 camcorder and ccd imager will be replaced to get live view for recording, lens cap message will disappear as well.
JVC will repair your camcorder free of cost for same problem, click JVC CCD Imager Support for details.
Thanks.
Sep 18, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Camera seems to think that the lens cap is on, there is no image (and no the lens cap is not on)- jvc mini dv camcorder gr-d347u The message "Lens Cap" appears when the camera is turned on, there is no...
There are 2 possibilities for that symptoms in JVC GR-D347U camcorder is either aparture in lens mechanism is stuck and does not pass image towards CCD Imager OR ccd imager itself got bad.
Qualified camera tech can fix it because it requires expertise.
If you want to fix it, download service manual from HERE for small fee, that will help you how to disassemble/ apart camera and part info etc.
Thanks.
Aug 13, 2009 | JVC GR-D347U Camcorder
Jvc video camera
there is a repir thing with certain models see below. CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
May 26, 2008 | JVC GR-D20EK Camcorder
JVC GR-D90 Camcorder Lens Cap Problem
http://www.jvcservice.com/service/CustNoticeCamcorder.asp?PgReq=DspDtaDtl&MdlNbr=GR-D90US&Pgm=CCD
Dec 19, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
Lens cap on camcorder
My JVC GR-DX97 is doing the same thing. If pointed toward bright light slight image appears. Sound works fine. Stupid camcorder. I was also planning on using it Christmas morning. Doesn't make me want to run out and buy another JVC product.
Dec 16, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
JVC GR-DX67EK MINI DIGITAL VIDEO CAMERA
Previously, when I have experienced this problem, I have removed the battery for 24 hrs and on replacement switched the Camcorder to (M) and quickly pressed the "Menu" button. This has allowed me to scroll down the menu options to the Cam Reset option. Then I reset the camera and all is well. This has worked for the last 3 to 4 occasions, however, this time I cannot get the menu to stay on long enough to reset the camera. Any ideas?
Dec 10, 2007 | Video Cameras
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
161 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
