Question about Palm Treo 600 Handheld
Replacing the battor
After replacing the battor and recharging my treo still wont start amy ideas
  • Anonymous Sep 03, 2008
    how do i ope the back
How 2 open the palm
Posted on Sep 03, 2008
My sons rca 10.1 tablet wont power up.....right before this happened it was froze on the start up screen and wouldnt power off. I let the power run down hoping then I could charge it and it would power up...
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jan 19, 2015 | Tablets & eReaders
Tip
Poor Palm Treo Battery
If you encounter a poor battery life on your Treo 680 and you have to recharge very often even if not using the phone function, the issue might have been caused by an incorrect first charging of the device. Please follow the steps below to solve the issue:
1. Connect your Treo to the charger.
2. Remove the battery from the Treo and wait for at least one minute.
3. Remove the SIM card from the device and wait for another minute.
4. Put the SIM card AND battery back into the device and charge the Treo for at least 4 - 6 hours. Do NOT press any key after reinserting the battery. Do NOT switch your TREO On or Off either, it will do so automatically after a short time. Do NOT enter the SIM card PIN if prompted to do so, just wait!
After this procedure, that can be performed and repeated any time, you will now dispose of the full charging capacity and the display of the remaining battery power works correctly.
on Mar 15, 2008 | T-Mobile Dash Smartphone
My C Class 220 cdi wont start completly dead hazzards wont even come on any ideas
Most likely its a drained battery have you tried recharging it? or 'jump lead' starting from another battery?
Dec 15, 2010 | 2002 Mercedes-Benz C-Class
2006 dodge durange wont start tried to recharge
Some times battery's are beon recharging that recharge wont do it, after you recharge battery turn your lights on, if very dim or dont come on, battery is no good replace it, also try to start it it if lights go off, replace battery.
Jun 23, 2010 | 2006 Dodge Durango
My wi power source just quit
Guest: Rechargable batteries are only 1.2 V each. You should get up to 4.8 V.
I highly suggest running your Wii Fit on nothing other than Alkaline batteries. I've had my Wii Fit for over 3 months and still use the original batteries.
If you feel like you need rechargables, that's fine, but I recommend a quality set of regular AA rechargable batteries that comes with a quick charger (IE: 1-hour). Stick to the same brand of batteries and buy enough for each Wii-Mote, Wireless Guitar, Wii Fit Balance Board, etc.
Amy - Keep in mind that your Wii Fit balance board will ONLY turn on when your program (ie: Wii Fit) is loaded and ready to go. Since the balance board takes up one of the four available Wii-Mote channels, make sure all but one Wii-Mote is turned off before starting Wii-Fit.
Apr 29, 2009 | Nintendo Wii Fit for Wii
Had constant restarting problem..now phone wont turn on
Could be hardware related but I would confirm your Treo OS is the latest version. There have been a couple of updates since the Treo 650 was launched. Note that the updates are service provider specific (i.e., if you are on Sprint PCS make sure to get the Sprint PCS specific update, etc.)
Aug 10, 2008 | Palm Treo 650 Handheld
220 Plantronics stopped working
Look under my name and find the previous 10-20 posts helping others with similar problems on adding/removing the existing connected device. However the Plantronics 220 Express and regular have connection problems with phones if they are far away, and sometimes get corrupt, unfortunately, for a $28.00 headset, its build for $28.00 of use.
Please review my previous posts and see if this can help you at all..
ManOwar
Aug 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Jan 04, 2008 | Palm Treo 650 Handheld
Problem Getting My Palm 600 To Recharge
Try plugging the Treo in to recharge and then at the same time poke the reset hole in the back of it. This should reset the charging mechanism in the Palm. Let it sit for a hour or so and then try powering it back on.
Jan 02, 2008 | Palm Treo 600 Handheld
Palm treo hot synch
try restarting the computer. it works for me
Aug 13, 2007 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
20 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
