Question about Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White
No water going to ice maker water is going to the cup fill
  • 351 Answers
Most likely the ice maker itself is bad. You can test by grabing you a cord with two terminals on it and plug it in the ice maker (like a jumper) if it goes in the ice maker then the ice maker is bad. If not change the water valve.
Posted on Mar 13, 2011
The ice maker on my Kitchenaid KBF320EVMS4 french door refrigerator stopped working. The drinking water works fine and I can hear the noise when the ice maker fills with water but no water comes in.
you can pop the cover off of the ice maker,on the module you'll see some letters,if you get a jumper wire and stick it into the T and H the ice maker should start to spin,if it doesn't the ice maker is bad,then remove the wire and stick it into the V and L,water should start to fill the ice maker,if it doesn't most likely you have a bad water valve,just get a piece of wire,strip off both ends to make a jumper wire.one more thing,check the fill cup and the fill line to see if there's any ice in there,if the water valve is bad water can drip through and freeze in the cup or fill line stopping the water from entering the ice maker,if there is melt it out with a hair dryer,also if you have to get in there with a hair dryer be careful with the heat on any plastic parts,you can damage it and don't heat the fuse on the ice maker wires,it's a black fuse built into the harness you can damage it if it gets to hot.you can go here to see your parts
https://www.searspartsdirect.com/model-number/KBFS20EVMS4/0593/0161000.html?searchType=modelSearch&q=KBF320EVMS4&searchTerm=KBF320EVMS4
Nov 22, 2017 | KitchenAid Refrigerators
Every time ice maker runs, water accumulates at the bottom of the fridge. It is a bottom freezer model made 9-2013. What could be plugged?
Check the ice maker fill cup, it could be full of water or ice and all the water misses the ice maker. Check the fill line in the freezer to make sure its in the full cup to the ice maker. CHeck the drain under the evaporator in the freezer to see if it is open and obstructed. Thats what I would look for. Good Luck
Apr 20, 2016 | Refrigerators
Ice maker is not making ice.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Jun 04, 2015 | Refrigerators
Ice maker is not producing ice and the control light is blinking red
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Install nocold refrigerator icemaker
Jun 02, 2015 | Refrigerators
I have a Whirlpool model # ET1CHEXVB00 refridgerator. I just (few minutes ago) replaced the ice maker valve because water was no longer getting to the icemaker. Very shortly after I plugged the...
Sounds like the fill tube at the ice maker is either out of alignment or has a crack in it.
The water supply line from the water inlet valve enters the rear of the freezer and releases the water into a large diameter fill tube. The fill tubes hangs above the fill cup which funnels the water into the ice mold. If the fill tube and fill cup are improperly aligned, water may spill out instead of going into the mold.
Nov 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
Ice maker
check the fill cup on the back of the ice maker for an obstruction of frozen ice, it the fill cup is frozen over then the water entering the ice maker will cascade over the frozen ice down into the freezer
if frozen melt it with a hair dryer then it will be ok
Apr 20, 2008 | Maytag MZD2752G Side by Side Refrigerator
Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
76 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
