Question about Microwave Ovens
I have to replace a cartridge in an Alder Tapware Milano single lever kitchen sink tap mixer. I need to know how the mixer disassembles. So far I have been able to remove the socket head grub screw but that is as far as I have been able to get.
2 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: I have a mixer tap
You will have to turn off your water mains and strip your mixer tap. It is possible that the seal (if it is an older tap with a rubber seal) has become stuck or the threaded part that turns it has gone faulty. If it is a modern tap with ceramic seals, check the operation of the mechanism and see why the ceramic seal is not being opened.
Posted on Mar 26, 2011
Kitchen Aid Mixer Model KSM5PSGR . I have had this mixer for about 15 years and recently while mixing dough, it started struggling to spin, and at some point stopped spinning. I just turned it on, and it...
it's possible the brushes on the motor are burned out. Are there 2 screw holes on the sides? You should have one on either side that look like a flathead screwdriver would fit in them? If so, inside those chambers are the brushes and springs for your motor. You can try replacing them. You should be able to order replacement brushes based on your model number(found on the bottom of your mixer). Let me know if that helps.
Jun 10, 2011 | Microwave Ovens
I have a price pfister kitchen tap and it doesn' have a cap. how do i get the handle off to replace the cartridge
If this is the single-handle faucet I remember, there's a decorative hot/cold indicator on the front, a small half red/half blue circle. This pops out of the handle to reveal the retaining screw underneath. It's a hex-key (Allen key) screw but I don't remember the size. Once you've loosened the screw you'll be able to lift the handle off the faucet body to get at the cartridge housing.
Apr 03, 2011 | Microwave Ovens
I have a mixer tap in the kitchen sink. The hot water tap runs fine but I am not getting any cold water. I also have a bath downstairs and the cold water tap there is fine
Mar 26, 2011 | Microwave Ovens
Hi, we have a tapmate futura kitchen mixer tap that is constantly dripping. you used to be able to buy spare seal kits direct from the Berglen group in watford but seem to have disappeared any one out...
The suggestions above are rubbish. The problem is common with the Futura, because the spout is moved usually through 180 degrees. The kit consists of a plastic barrier washer, and o ring. Sometimes with the replacement grub screw. Tapmate was Berglen and Berglen was swallowed up by Damixa which in turn was taken by Bristan who have some spares but I don't know if they have this. Otherwise there is an overseas website for Damixa
Mar 08, 2011 | Microwave Ovens
How do I get to the cartridge to see if it is blocked in some way. I have reduced flow. This is on my kitchen faucet. American Standard Jasmine Kitchen faucet
You have to turn off the water and disassemble the valve from the top side. Check your screens at the discharge point, particles block there, also.
Mar 05, 2011 | Microwave Ovens
I got EMG4753 microwave oven...now 4 yrs old....it's door is not opening when press the door opening lever...pls advice
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety & disassembly info here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Sanyo UK support, parts and authorized servicers here.
Jan 18, 2009 | Microwave Ovens
Door Will Not Close/Open
Please unplug the oven before disassembly.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and get part numbers by entering your model number at the Sears parts site.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 14, 2009 | Sharp Microwave Ovens
Microwave Ovens Logo
237 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
