My whole house is heated with electric baseboard heat,1 thermostat keeps blowing out.have replced 3 times in 1 year
  • 1,420 Answers
You will need to put an amp meter on one of the power lines to see what the element is drawing for amperage. It is amperage that produces heat and will shorten the life of any switch including the thermostat. Compare your findings with the rating of the thermostat.
Posted on Mar 13, 2011
How to set heat for baseboard heat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Oct 01, 2014 | Honeywell Heating & Cooling
Replacing a Honeywell T822l1000 thermostat.
The W terminal is used for heating and goes to a small electric valve in the water line to your baseboard. The Y terminal is for a cooling system. The T822 is wired wrong and is not working. The wiring between R and W is corect for a heating only application. The R terminal is the power source.
Nov 10, 2013 | Heating & Cooling
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
Above some of the baseboard electric heating vents (the whole house is wired with electric (not gas, oil, or coal) heat there are black marks on the walls. what is causing this??? I do not burn candles,...
While it could be nothing, it is a good idea to have a heating professional check them once in a while. Sounds a little odd, though, as most electric baseboard heaters have no vents. You will be comforted by the reassurance of having them looked at. Farmerbear at FixYa.com
Sep 28, 2010 | Fahrenheat Built-In Baseboard Thermostat...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
How do you reduce an electric bill in a all electric house?
The biggest wasters of electrical energy are Heat and A/c, water heaters,dryers and ranges. The more you insulate the less you have to cool or heat. If you live in a warm climate, consider installing an attic fan that runs on a thermostat or timer. During the summer allow it to run, during winter turn it off. Ceiling fans in rooms that are occupied create the illusion of being cooler, allowing the thermostat to be turned up.I'm not sure of the exact numbers but any thermostat setting on your a/c below 78 is more inefficient so try kicking the a/c up and the heat down. I'm a Florida boy so I can't tell you much about baseboard heaters. I know that anything that heats things up cost a lot in energy.
Consider installing a hot water heater timer. Commonly called a "Little Grey Box". Whenever your water heater is not actually being used it is still heating the water. A big waster. Once installed set the timer to cycle the water heater off during times when you commonly don't use it. Overnight,when your at work etc....
Somewhat antiquated, but a clothesline always uses 100% less energy than a clothes dryer. :) Short of this, try to fill the dryer all the way and make sure your dryer vent and lint trap are clear.
Microwaves draw 1/3 the energy of a range and run for 1/10 of the time. Microwave as many things as you can. In our house we have started microwaving canned veggies and boxed side dishes and such.
These are the big ones I've done at my house. A lot of the other things seemed to be more work than they are worth. Some actually end up costing you more if you don't own the house for decades.
There are many sites you can visit such as your local power company and possibly your local government pages.
Good luck. I'm in the same boat with the high power bill.
Mar 24, 2009 | Fahrenheat F2543 Baseboard Heater
Cadet Thermostat
from the mod number it looks like you have electric baseboard. these do not have blowers in them they work off natural air movement. but heat up rather quickly. your gonna have to chk if baseboard is getting power to determine weather or not the t stat or the heater is not working. but first chk your circuit breakers. most heaters are 220v (double breaker)
Mar 19, 2009 | Cadet Manufacturing 6F1500W Baseboard...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
