Question about Ridgid Rigid Tool 31030 24" Heavy - Duty Pipe Wrench - Cast Iron
Rigid pipe wrench-how do you replace coil and flat spring??
  • craig storm Jun 08, 2012
    wich end is up? i dont have old one to copy.
Take out the sliding jaw. Use a hammer in conjunction with a punch or screwdriver that will catch the front edge of the flat spring. Alternate between the top and bottom of the flat spring. You'll get to a certain point where the coil will pop out. Go slow as to not lose this spring. You can toss it after using it to match up to the replacement parts. Check the flat spring against the new one to make sure they're somewhat the same size. The next part is tricky, almost like shimming or keying a lock. I use a piece of banding material (1/2" wide and long enough to extend through the channel with the coil underneath) to shim between the flat spring and coil spring. Gently knock the flat spring in and remove the banding material from between the coil spring. You're done. Reassemble the sliding jaw with knurled nut.
Posted on Sep 22, 2011
Pontiac G6 : Ready to pull the CV joint - seems hard to pull out - like it is stuck. Any ideas?
it is not stuck, there is a spring clip inside the transmission holding it, put a pipe wrench on the part closest to the transmission and tap the pipe wrench, it will pop out.
Sep 29, 2012 | 2006 Pontiac G6
99 Acura RL 3.5 horn does not work
You have a defective part called a clock spring contact under the steering wheel, this contact is a coiled up simi rigid plastic ribbon with circuits embedded in it, after many years they l break and you loose the connection from the steering wheel controls (radio) and the Airbag. You must disarm the airbag on the steering wheel and remove it and replace the clock spring contact drum under the wheel, the cost is about $300.00
Jun 07, 2012 | Acura Cars & Trucks
How to connect the alternative drain pipe. i see how to push it through the back but it is not secure and does not seal to the balck internal pipe. I only have white extension pipe
The alternative drain pipe, as you called it, is for a garden hose type connection, not rigid pipe. The connection is threaded, so that a standard garden hose can be screwed on to it. Rigid pipe like you are trying to use won't work.
Hope this helped to clarify the issue.
Mar 28, 2011 | Kenmore 54351 Dehumidifier
Suspension strut keeps spinning when i trying to remove it to repace spring
Most struts will have a hex shape (or perhaps two parallel flat surfaces) on the very top of the shaft to put a socket (or end wrench) on to hold while loosening the main hex nut.
This procedure would require the use of both hands (one to pull on wrench of main nut while other holds wrench to prevent shaft from turning)
Would not suggest, however, that you hold the shaft with pliers or pipe wrench. This could damage threads, making it difficult (if not impossible) to fully remove main hex nut.
You mentioned changing the spring....do you have a spring compressor?
Jan 30, 2011 | 2002 Hyundai Accent
I broke the pvc pipes that transport the water to the jets. I need replacement pipes. Where do I get those?
the PVC pipes used to plumb bathtubs can be either rigid PVC pipe or flex PVC pipe. You may use either kind and is usually available at your local Home Center.
Jan 10, 2011 | American Standard Colony Hydro Massage...
1999 hyundai elantra how to replace rear struts
Rear struts usually have a large bolt on the bottom and 3 little bolts on top, to allow removal.
But then you need special spring compressor clamps to take the tension off the coil spring, so that the top of the strut can be safely removed. Careful, because the springs can be very dangerous.
You remove the top from the strut by undoing the large center nut. If the shaft turns with the nut, use a small wrench on the flats in the end of the shaft. Once the top is off, then you remove the spring. The strut tube then has a cap retaining the insert cartridge that needs to be removed and replaced with a new one. Reverse the rest.
Dec 21, 2010 | Hyundai Elantra Cars & Trucks
My dryer does not heat up properly, model DPSB620EC4WW, I have replaced the heating coil but this did not correct the problem. Is there a repair manual that tells my how to check the error codes for this...
There is usually a " mini manual " which contains the electrical diagram and a bit of other information located inside the back control panel area. Before you go any farther though, check your dryer's venting. With the dryer running, go outside and feel how much air is comming out the vent. The air flow needs to be strong for the dryer to work properly. The most common problem causing poor drying performance is bad venting. Make the vent as short and straight as possible, with rigid aluminum vent pipe and elbows. If you must use flexible vent materials, try to make it as short and straight as possible, preferablly using semi-rigid aluminum pipe (the kind that you can stretch out, bend, and it just holds it's shape) don't use the plastic stuff with the strand of wire in it if you can avoid it in any way. You may also have to clean the lint out of the vent pipe.
Feb 07, 2010 | GE Profile DPSB620ECWW Electric Dryer
How hot is the Vent temp of my new Duet?
It's not the temperature of the air that is the problem. The air is seldom over 160 Deg F. If you have a vent fire the piping needs to last long enough without melting to starve the fire of oxygen in the hopes of extinguishing. Rigid aluminum piping is best suited for this, Rigid flexible is next. The tin foil and white plastic offer little resistance to melting if a fire should begin. The melting would allow the fire to replenish oxygen and support the burning process. The main caution here is to keep your dryer and vent clean...at least annually.
If the duct inside your wall is rigid metal all the way from the dryer to the house exit you need to do nothing to it . Replace the vent between the dryer and the wall with rigid metal 4" piping or hard flexible aluminum piping. If the duct inside your wall is either of the least effective types you need a new run of vent for the dryer to avoid a fire.
You can't use white plastic or flimsy flexible aluminum that feels like aluminum foil when you touch it.
Sep 10, 2009 | Whirlpool Dryers
I am installing a new kitchen faucet and have two problems. Number one the plastic flange njuts that hold the old faucet to the sink won't come off. I tried to loosen them with WD-40 and white vinegar. No...
First of all, you need a faucet wrench. It's about 12 inches long, has a t-handle on one end and jaws on the other -- this will grip the plastic nuts to remove them.
I'm not sure what is meant by breaking the seal. If the soldered fitting broke loose, the best approach is to cut the copper pipe off past the damage and solder a new fitting on it necessary for the new hose to screw onto it.
There are a lot of ways to solve this problem -- if you can't manage the soldering, we can discuss other options.
Apr 20, 2009 | Plumbing
Maytag Performa dryer venting
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
Sep 01, 2008 | Dryers
Ridgid Rigid Tool 31030 24" Heavy - Duty Pipe Wrench - Cast Iron Logo
279 people viewed this question
Top Ridgid Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Ridgid Measuring Tool and Sensor Expert? Answer questions, earn points and help others
