Question about Health & Beauty
We replaced brushes on motors battery has full power.Joystick control lights flash chair will not move
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
GOD I LOVE BEING HERE FOR PEOPLE LIKE YOU,PLEASE DOWNLOAD :SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 THAT WILL GIVE YOU WHAT YOU NEED,COLIN.
Posted on Mar 14, 2011
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
When plugged in lights indicate full charge,when I pull plug all lights go off,won't move this is a jet 3
Something between the batteries and the motors and joystick is interrupted. Recheck fuses and connections.
Aug 08, 2014 | Jet 3 Ultra Power Chair
HS-2800 Power Chair is moving extremely slow....
Poor batteries or very weak batteries Also make sure you have the speed control to full in a safe area and try it there. But my bet is on the batteries Good Luck
Nov 15, 2010 | Ctm HS-2800 Power Wheelchair
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Aspire m-11 has erradic light flashing and occasionally chair will lurch fwd. the joystick receives light input but chair will lurch. has orig. 3 y.o. batt.'s whatta ya think??
Hi. Lights flashing is sometimes a fault code. Count the flashes. Sometimes The lurching is caused by the motor brushes jaming or bouncing in the motor. I caused the motor to stop and start erratically. Usually happens in machines that have done a lot of use. Get a serviceman to inspect the brushes and see if they are worn down or have been jaming in the brush holders.
Check all the plugs and connectors including the motor and battery connectors. I have replaced a lot of battery and motor connections because they cause intermitent faults. Good luck. Neil.
May 13, 2010 | Health & Beauty
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
Where do I find a wiring diagram for the jazzy 1103 ?
Here's a link to the Pride Tech Manual guides. Click on the 1103 for a PDF file.
http://www.prideservice.com/TechnicalProductGuides/technicalproductguides.asp
The wiring is pretty simple and straightforward. These operate on a 24VDC system provided by two 12VDC batteries. Power from the batteries goes to the controller into a Joystick/controller combo. It leaves the joystick down to each motor/gear/brake assembly. Power to the batteries comes from the charger which puts out 28VDC, with a 120VAC input. Very rarely does any of the wiring go bad excepting those people who grossly overload the chair, or run it into fixed objects at full speed. Other mishaps with overamping are caused when somebody tries driving over unstable surfaces like sand, gravel, mud/wet grass and spin the motors. This drives the controller crazy because its job is to keep the chair pointed in the right direction, and with wheels spinning, it doesn't know what to do. Overheating the motors or controller, or both. There are two sets of "brushes" on each motor that carry the current from the batteries to the motor. These are located under a black-plastic slotted screw port at the ends of each motor. Removing the plastic screw reveals the brush. It should have a flexible semi-copper lead that shows no evidence of overheating, or brittleness, and should be about 3/4 of an inch long. If 1/4 of an inch, it should be replaced. Check all four. Good luck.
Jul 10, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Won't move pronto m51
Three lights flashing on your chair indicate a left motor fault. Make sure that all of the connections inside the shroud are tight by physically testing them. If all of the connections are good, and the fuses are good, then it's time for a trip to an authorized repair facility. Here is a link to the M51 owners manual if you haven't one. Page 24 has the fault code guide.
http://www.invacare.com/doc_files/1125085.pdf
The controller monitors all of the functions on the chair, brakes, motors, joystick, charger etc. The three flash fault indicates an "open" circuit. Open, like a switch or blown fuse is open, or a wire is cut or burned in half, or a connector is unconnected, or partially connected. The latter is what you are hoping for. Wires burned in half is the usual cause for a motor fault, and with powerchairs, is usually the result of the chair getting stuck in or against something it can't get out of and the operator over-amping the motors. Motors do, just go bad sometimes, for no reason. Very rarerly, however.
You can also check the brushes on the motor too. There's two quarter-sized black plastic screw-plugs on the ends of the motor opposite each other. Unscrew them and examine the brushes. The springy coils should be springy. Overheating can cause them to be brittle, or even burned in two. Check the lench of the brush, the dark rectangular cube at the end of the springs. It should be curved and polished at the end, and a little over a half-inch long. If it is near a 1/4 inch, it needs replaced, or if there is any evidence of overheating, replace. Good luck.
Apr 19, 2009 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
