Question about Boating
The low water pressure and overheating alarm has gone off 5 times in first 10 hours of operation on my brand new 2010 225 yamaha series II outboard. I hear the lower unit water intakes are designed bad and this is a re-occuring problem. How can I gert more water to the motor. Is YAMAHA aware of the issue?
    President:
  • 1,654 Answers
Not seeing anything particular, especially on this motor, there have been overheating on different models but nothing new like yours. Since it is new, please call the dealer who sold this to you, there is factory warranty that you need to use, if you alter anything then the warranty will be void. With that said, always make sure the stern is in the water deep enough to draw the water in, if trimmed it losses its ability to draw water like it should. The Poppet valve could be sticking or the thermostats can be bad, this is not that uncommon. Ther is also the hose that connects inside to the water jacket that may have come loose and not impossible but maybe you sucked up something that hurt the impeller for the water pump. Bad timing can cause this as well as a cylinder not getting the correct amount of oil. These thing can fall under the lemon law just like cars, if the motor had issues when you bought it, the manufacture is required to fix these issues. I wish I had a canned answer to this but there is none. It could be as simple as a bad temp gauge giving you a false reading. Does the motor actually seem like it is running hot or is the alarms just going off? 10 hours isstill a brand new engine and the dealer should have to remedy this. You need to find out if it is overheating or there is some other problem like running lean, as either one will destroy a motor if you keep running it like that.
I assume you checked the intakes for blockage, and the water coming out of the weep hole is strong and warm. You can try cleaning the weep hole with some weed trimmer string to see if something is blocking the exit.
Posted on Mar 14, 2011
My 1995 90 horse Yamaha runs 5 at 5/8 throttle but if you open it wide open for about two minute alarm goes off and it shuts itself down what's the problem
alarms that shut the engine down will be connected to engine head temperature, water pump pressure /flow or fuel mixture
check that when a full rpms there is a good water flow from the telltale or if you have a pressure gauge fitted for the cooling system check that it is at operating pressure
check that there is not an over heating problem or a fuel flow when there is a need for full fuel flow
discuss the prob lem with an accredited service agent to check for service bulletins on the problem
Jun 12, 2017 | Yamaha Motorcycles
Yamaha 115 4 stroke alarm sounds when boat is in neutral. forward or reverse no alarm. oil is good and water out of the spout.
Which alarm is sounding? Oil or overheating? You need to figure this out first! ... Is the water coming out of the spout high pressure or can you hold your finger over it and stop the flow? If you can stop the flow, you have a bad water pump impeller. If not... you are probably getting good water pressure. If your oil tank is full, the low level sensor is dirty or bad..this will cause the alarm..Fix each of these and repost.
Jun 06, 2017 | Yamaha Boating
Engine overheating
Hi, M and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
11. Idling too long without moving.
12. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.carpe-tdm.net/tdmforum/viewtopic.php?t=773&view=next&sid=6f7f6195c657c247bf3882a2512729be
1996 2001 Yamaha TDM 850 Service Manual Moto Data Project
OEM parts for Yamaha
YAMAHA TDM850 Owner Manual
Sep 24, 2016 | 2000 Yamaha TDM 850
1994 Yamaha 150HP Outboard
Good Afternoon BayouNola,
This Sounds Like A Loose Connection Problem,
The Tach Is Directly Related To The Charging System,Please Check Your Battery Terminals ,Clean And Secure Tightly To The Battery,
Unplug The engine Electrical Harness Check Clean And Re plug,
Check The Main Fuse For Corrosion And Rectify If Necessary,
If The Engine Was Getting Hot The Alarm Should Be A Continuous Alarm, If It Is a Intermittent Alarm It Is Oil Related !
If In Any Doubt Run With Pre Mixed Fuel,( 500 Ml's In 25 Ltr's Fuel) Until The Problem Is Solved.
Good Luck Gordon
May 07, 2014 | Boating
Yamaha r6 overheating
Hi, Anonymous and the usual suspects are:
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
http://www.r6-forum.com/forums/65-new-member-section/160259-02-r6-overheating-problems.html
R6 is overheating BAD
2007 Yamaha YZF R6 Service Manual R6 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 22, 2012 | 2007 Yamaha YZF-R6
My yz 80 overheats soon as you start it
Hi, Jamie and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
YZ80 overheating and no powerband
YZ80 overheating problem
1994 YAMAHA YZ80 YZ80F FACTORY OWNER REPAIR SERVICE MANUAL Download... $10
Mar 20, 2012 | Yamaha Motorcycles
YAMAHA 2001 40 HP NOT PUMPING WATER,PUT OUTBOARD DEEP INTO CONTAINER OF WATER,AND FAILED TO PUMP OUT WATER,EVEN AFTER LOW REVS,SWITCHED OFF IMMEDIATELY BUZZER ALARMED
Hi, it needs to have the water pump overhauled and it is not something you should attempt on your own. Take it to someone experienced to have it done correctly. Regards Phil.
Nov 01, 2011 | Light Outboard Motor Boat Bass Fishing...
2008 Yamaha YZF-R1 engine overheating
Hi, Elcapxy and the usual suspects are:
2008 Overheating
R1 Overheating what could be the reasons
Yamaha YZFR1W 2007 Service Manual
Yamaha 2007 YZF R1W Owner Manual
Jan 26, 2010 | 2008 Yamaha YZF-R1
Boating Logo
63 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
