Question about Motorola Mobility Karma QA1 Cell Phone
Can only hear calls when on speaker phone. camera pictures getting fuzzy video tape cuts off short
  • kitloveland Apr 08, 2011
    can speakers be replaced? want is weird is it stopped working for a while, then worked for a
    few weeks, now it is back to speaker only. I think there is a connection problem. what do you
    think?
    President:
  • 2,047 Answers
Usually when you can only hear calls on speaker phone it is as a result of 2 things. The first being a reduction in the volume, there are various ways to adjust the volume you can use the navigation keys in the middle of a call and that will increase the volume or you can refer to your user manual for methods of increasing volume. Although the hearing problems could also be caused by burnt out speakers. Atimes the speakers which enable you to hear without speaker phone could be damaged therefore your not being able to hear this may need to be replaced in this scenario.
the camera pictures getting fuzzy could be as a result of the phone falling down or the camera lens cover being dirty or the lens getting weak any of these three could cause fuzzy pictures. While videos being cut short is likely as a result of low memory space.
Will do some more research on the video problem and get back to you.
hope the other solutions have been helpful?
Posted on Mar 13, 2011
  • Rockme
    Rockme Apr 09, 2011
    definitely the speakers could be connection problem but most likely when you open to check the speakers there is no particular way to ensure that the speakers are still good so best option to avoid double cost and issues is to replace the speakers.
    And yes they can be replaced.
Playback 8mm camcorder tape fuzzy
8 mm and the newer super 8 mm video tapes are different. You can't use super 8 mm in old player. And old tapes won't play well in new super 8 mm players. Like Sony!
Nov 04, 2013 | Video Cameras
Vcr tape play fuzzy
You need to clean the video head.
Apr 14, 2013 | Televison & Video
I dropped my cellphone and now I can make a call but I can't hear the person on the other end. They can hear me, what can I do?
Hello and Welcome to FixYa!
The problem is simple, I have had this issue with many of my cellphones. The reason behind this is a faulty Ear-piece (The Small speaker unit that is on the upper side) If you have a Loudspeaker in your Phone you may hear from the load speaker because Loud speaker is always a by-bass to Ear-piece. The Loud Speaker may also be damaged as your phone got impulse. Neither you can listen to them when making a call nor receiving a call. The solution is to get your phone serviced, I'll not tell you to replace the Ear-piece directly. Because there are also cases when the Ear-piece is ok but due to the phone slider or flip open the body strip got damage due to which this response is generated. So to cut the story short you have to go to a nearest server center and ask them to service your phone as you are having this problem. They will diagnose, then act accordingly.
I'ts not at all expensive. And I'll not recommend you to do it yourself, as you may end up in more mess.
I Hope you will have a clearer picture now. Concerned, Nooh.
Aug 03, 2011 | Cell Phones
Picture playback on hi8 tapes distorted and fuzzy
Hi I am Vortash get a tape head cleaner for Hi 8 cameras and try that , most people never actually clean the camera it's something we all forget to do if its not tha you may have contamination in the lens or a taget imager fault regards Vortash
May 31, 2009 | Sony Video Cameras
Logitech Quickcam Deluxe causes speakers to go out.
Have you set your cam up on skype
Go to TOOLS, then OPTIONS, and click on Audio Settings
and set the Microphone and Speakers
to the computer Audio Card.
Then click on the Video Settings.
The camera if installed properly
will come up and show a picture.
Then on the bottom of the page click on Save.
program
Jan 26, 2009 | Logitech Webcam
Fuzzy picture
The tape is not adjusted to cylinder head. Both the sound and picture is lost when the tape is not exact on the wheel (head). If the camera has not been used for a long time then can the adjustable pins start to rotate and change the position of the tape when it is used again. The oil has dried out and the pin is not running smoothly, and the screw starts to rotate as well.
So, the solution.
a) remove the plastic cover so you can see the two pins that pulls out the tape from the cassette.
b ) small droop of oil on the top of the two pins
c ) use a small screwdriver to change positions of the tape, by turning screw on the top of the pins.
Put in the tape again and test , thus you have to do small adjustments. Repeat the test until you see the picture.
This is simple but it will take some time. I have now saved all old films, it is hard to find a old video-8 analog camera ....
/U
Jan 24, 2009 | Sony Handycam CCD-TR87 Camcorder
JVC Digital Video Recorder Problems
Most models of cameras have a built in feature to give you a message and turn off if it has condensation on the inside components. Powering back on during this period can cause damage to components. It should remain off in a warm dry area. Condensation might occur in high humidity, or when switching from a cool location to a warmer place. Try cleaning your video heads with a "cleaning tape" let it play for 10 seconds then pause. If that solves nothing your camera may have permanent damage in which case JVC or a repair shop will have to replace parts.
Sep 22, 2007 | JVC GR-DX100EK Mini DV Digital Camcorder
Motorola Mobility Karma QA1 Cell Phone Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
