Question about Sharp Microwave Ovens
Hi, I have a Sharps R-23 AM 1900W microwave. When i use it, it starts the timer and counts down for a few seconds then stops and flashes with 'err 3' on the display. Can you help at all with this? Thanks Steve
  • Sharp Master
  • 9,047 Answers
Is that code actually "EE3"?
If so, that is called a Magnetron (1) and (2) failure, but it may not be the magnetron.
It may be any of number of things, form door switches to control board relays to the high voltage parts.
Methodical troubleshooting is needed, and we have the manual for similar models here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Jvm1090aw. After using the convection oven the microwave will not function. Is this a moisture sensor or?
I have a jvm1090aw microwave oven and for some reason it just stopped working. It will still count down the timer but it won't light up and turn on. Also there is a small microwave icon flashing at the bottom right of the screen. Any ideas? Today I tested it again and started it for 30 seconds. The first 8-10 seconds nothing but silent counting down then it turned on for the last 20 seconds. It then turned on again when I tried it immediately after that but nothing 5 minutes later.
May 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Frigidare FMV156DCG Overheated?
I have the same problem....I think its the door switch because if you lift up on the door handle while you've got the timer counting down, it should start the microwave hum....
Apr 26, 2009 | Electrolux Microwave Ovens
Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes the problem can be undone also.
Feb 09, 2009 | Sharp R-540DK Microwave Oven
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Oct 12, 2006 | Panasonic NN-T990SA Microwave Oven
Microwave Ovens Logo
182 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
