Question about Sport & Outdoor - Others
Snk 70 watt fitting switching off, new ballast and bulb fitted
chrispurs1
  • 372 Answers
SOURCE: the bulb doesnt light up when switching on!! brand new bulb also been fitted
Hi.
Your friend could be right but before spending more money check the cooling fan is free to spin the bulb will not start if the fan isnt spinning.
http://dysonmanuals.inc.io/
Chris.
Posted on Nov 09, 2007
SOURCE: WOlfgang Puck Deep Fryer 1500 watts power cord
Hi - The 1700 watt fryer uses a magnetic release cord set type TA 35 P. If your unit says "use only with TA HSING CORD SET TYPE TA 35P, It should work.
Posted on Jan 25, 2008
  • 29 Answers
SOURCE: volvo v40 main beam light wont work
its the switch unit itself
Posted on Mar 19, 2009
SOURCE: 2004 Landrover Freelander stop/reverse light fuse keeps blowing
I had a persistent problem of hill light warning and TCS warning lights coming on for no apparent reason. There is a wire connection between the stop light switch and the control unit to let the system know when brakes are being applied. Changing the stop light switch cured it. The replaced switch was certainly sticking and the new one was of a different design. Replaced it myself as switch comes with a wiring loom. Need to get on your back under the steering wheel! Not very expensive. My car 2001 TD4
Les
Posted on Jun 30, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Re fitting a Bosch GT40R-T ignition coil to a Ford V8
The ballast resistor only weekens the power to the contact points while the engine is starting after that the secondary wiring "is" a built in resistor. I suggest you use the ballast or you'll be changing a lot of point sets.Just out of curiousity, why would you want to convert back to an older and proven obsolete type system?
Posted on Aug 25, 2009
What is the brightest replacement headlight bulb for a 1999 Toyota Camry?
in older vehicles you put a 100- 125 watt H4 bulb (with relays ) as the reflector was metal and could stand the heat
modern cars use plastic reflectors so going over 65-85 H4 would probably melt the reflectors
Leds are a better option as they produce little heat but the installation is not straight forward as they need ballasts fitted to activate properly
I would have a talk with an auto electrician that knows how to fit the led lights and what is required.
Aug 23, 2015 | 1999 Toyota Camry
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
52WM48P Rear projection TV Lamp fitting
Original brand Toshiba lamp ,unit price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 13, 2014 | Lapbix Tv Lamp For Toshiba 52wm48p 120...
Need a replacement ballast for glo double 54 inch T5 HO aquarium light
Hagen has a massive website and they sell parts for virtually everything they make.
This is one page from their Canadian site listing ballasts for their lights.
http://ca-en.hagen.com/SearchProduct/ProductPageSearch?page=1&resultsPerPage=25&keyword=ballasts
Jan 10, 2014 | Hagen Glo T5 HO Electronic Ballast for T5...
Purchased the 70 watt fixture and supplier said I could put in a 35 watt bulb because I didn't want it so bright. The light goes on but exceeds 35 watts and then shuts off after 5 min. Is it possible to...
The simplest thing to do would be to use the 70 watt bulb and then install a dimmer switch...that way you can dimm to what ever level you want and still have the full brightness if you want....
dimmer switches are not that exspensive and are easy to install...
heatman101
Sep 08, 2010 | Garden
I want to place HID lights in my 2006 R6. Would
Generally the ballast is a separate box that is external to the headlight unit. HIDs4U does slim fit kits especially for motorcycles.
You may have to modify the bulb holder to get the cables through to the new HID bulb.
Apr 23, 2010 | 2006 Yamaha YZF-R6
Why does 2002 Firebird Trans am drivers side turn signal only work manually. Bulbs checked and r ok
try the earth connections and fit another earth if need be, also check the wattage of the bulbs ,12v 21 watt not a side light bulb of 4 watt which i suspect you have fitted
Jan 03, 2010 | 2002 Pontiac Firebird
Indicator relay switch location on gsx 1400
After market indicators were fitted. The front lenses only had 5 watt bulbs fitted causing the problem. Upgrading to 21 watt bulbs fixed the problem.
Apr 17, 2009 | Suzuki GSX 1400 FE Motorcycles
Hello...need help.. replaced 600mh bulb then
Have you tried the switch yet? The plastic switches inside some ballast boxes don't do well with the heat produced by the ballast. You can try to simply bypass the switch and hard wire the ballast to the plug to test whether or not that might be your issue. If you need a new switch, just call Sunlight Supply directly http://www.sunlightsupply.com/hort/contact.aspx they should be able to send you a replacement switch.
Feb 18, 2009 | Sunlight Supply 400 Watt Hps Sunsystem I...
The bulb doesnt light up when switching on!! brand new bulb also been fitted
Hi.
Chris.
Nov 08, 2007 | Televison & Video
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
