Question about Sony Playstation 3 (PS3) Console
Plastion network is not working my connection to the internet is 100%. it aint getting the IP address and that is pretty much it. what do i do?
  • 30 Answers
Have you tried reseting your router? I've had a similar problem where I've tried to connect to the internet and I was able to get on my laptop and other internet devices. However it wasn't in till I restarted the router that it started working. If its not the router then perhaps retry configuring your internet on the PS3.
Posted on Mar 14, 2011
I cant get my home computer and lap top to both go on line at the same time
A "hub" just "splits" the Internet connection.
Each computer connected to the hub gets an IP-address from your ISP (Internet Service Provider).
However, some ISPs only allow each customer to use _one_ IP-address.
Ask your ISP for the capability to obtain a second IP-address.
Mar 18, 2011 | Linksys (NH1005) 5x10/100 Mbps Networking...
After updating ubantu 10.10 maverick(?) desktop edition my internet connection (via wired connection aka eth0) has gone BUT i can still access my router (connected to cable modem) and all other machines on...
Try:
sudo route add default gw ROUTER.IP.ADDRESS
Replace ROUTER.IP.ADDRESS with the address of your network router. If you don't know what this is, do the following in Windows XP:
Start -> Run -> cmd.exe
ipconfig
(look for "Default Gateway", and write down the four numbers - usually something like 192.168.1.254 - that's what you should use for "ROUTER.IP.ADDRESS" above).
This will fix it for your current session - to make it permanent, open up the network configuration window in Ubuntu, and set this as your gateway under "IPv4 settings" (or similar).
Nov 16, 2010 | Canonical Ltd. Ubuntu
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Default ip address?
Hi,You are right mvincentc , for more IP related informations you can use this http://www.whoisxy.com/ site for best result.here only i got my exact address and other details,It is totally free site .visit here for more details.
Jun 05, 2010 | Milan Technologies ShAir AccessG Pro...
I have a windows 2003 SBS Standard Edition and IP Address: 192.168.1.5 also a Linksys WRV210 and the IP address 192.168.1.1 I have setup a preferred DNS on all clients to 192.168.1.5 The internet is not...
For that connect your router to directly to lan ports of your server.and install another ethernet lan card on server so that ports connect with switch.
Then configure your router as bridge connection then set dns as your server ip in all computers.Then you can get 100% fast internet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 15, 2009 | Computers & Internet
I have my internet through my cable company and i want two com hooked up but are not going to have them online at the same time so can i use the 10/100 5-port model#EZXs55w by using the line coming out of...
Hello Friend
You could definately use Network Switch-10/100 5-port model#EZXs55w to Connect to Network Router or Modem using Uplink Port at back Panel of 10/100 5-port model#EZXs55w Switch.
Simply Connect Modem cable to Uplink Port of Switch and connect computers to other 2 ports of switch. Allow computers to get Automatic ip addresses..if computers still not getting ip addresses auto--contact cable company and config your cable modem to use NAT or enable NAT--
Oct 10, 2009 | Computers & Internet
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Jan 08, 2008 | 3Com HomeConnect (3C19261) 5x10/100 Mbps...
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
