Question about Kitchen Ranges
Location of inlet screen for maytag washer model#200xw00
  • 351 Answers
Shut the water off on each side. Take a pair of pliers and take the hoses off. And there you be they are right there in the water valve.
Posted on Mar 13, 2011
I need to know if Maytag Centennial washers have a drain screen in them? my wife may have lost her wedding ring in them.
Need the model number of the washer, if it is front loader the answer is yes it would have a screen at the inlet to the drain pump.
Jan 24, 2017 | Maytag Washing Machines
Dirty inlet screen maytag washer
These models actually don't have a filter so the best way to clean it would be by choosing a cycle which allows th most water to fill up the tub , hot water preferably and add some powdered diswasher detergent.To remove your agitator you will have to pull off the top portion and inside the agitator there is a hailf inch bolt to unscrew and the rest will come off.
Hope this helps
Apr 17, 2013 | Maytag MVWC200XW Washer
Maytag washer is very slow in filling with cold water. Is there some sort of internal filter?
Yes there is a screen. Remove the hose check the hose for a screen and clean. Also when you remove the hose there should be a screen in the end of the water inlet valve. If all is clear the water inlet valve is failing. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the process of testing the valve. Different model but same testing procedure.
Mar 28, 2010 | Maytag Washing Machines
NO HOT WATER MAYTAG WASHER Model # LAT9706AAE
replace the dual inlet valve located in the rear of the machine. have included a link to help you...you can also purchase the part from the same link. http://www.partselect.com/repair.aspx?appliance=washer&part=replace-water-valve
Jun 22, 2009 | Washing Machines
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Won't let cold water in
Take the water supply hose off and clean out the inlet screen located inside the water valve where the hose was attached to the machine. Note: there may be a screened hose washer on one end of the hose also.
Sep 24, 2008 | Maytag LAT3600A Top Load Washer
Hot water fill problem
Replace or clean your water inlet valve. It appears that the hot water solenoid has either become clogged, or had failed. You can find a replacement at repairclinic.com. Type in your COMPLETE model number in the Search window and there will be two of them located under the "Water Valve/Float" heading. Depending on WHICH type of valve you have, a replacement costs between $28 and $74. Refer to the part illustrations to make sure you are ordering the correct part. If you require assistance in accessing the inlet valve, let me know. I hope this helps you.
PS If you attempt to clean the valve, you will need to turn off the water supply and disconnect the hoses. Check the inlet screens for sediment or debris.
May 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
the only screens you can clean are located in the throat of the water inlet valve which can be acess from removing the water hoses, dont know where or what screens you could possibly get to be lifting hte top
Mar 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
